Hello,
In Resolume 7:
Clip is in piano mode, and in auto mode in play previous clip. When release the clip it good to black screen and not to the clip that was playing before. Is this a bug or am I doing something wrong?
Is there a work around?
Jump to previous clip not working
Re: Jump to previous clip not working
Auto pilot triggers when the clip reaches the end point. If you disconenct the clip manually by releasing it, then it won't reach the end for auto pilot to trigger.
Thanks but this is not really a good explanation of what I have to do to get it working.
So please can you direct me in the correct direction how I can configure how to jump to the previous clip?
You have to let the autopilot finish. That’s the key.
