Quality problem with output
Moustikseb
Post by Moustikseb »
I have a problem that has already been discussed, but I have not found a solution: I work on a PC with resolume arena 7. My graphics card is a radeon rtx3060. I create video clips in 1920 x 1080 that I use in a composition of the same format.
When viewing on the second screen, led panels with a pitch of 4.9, the video is really not beautiful, it loses enormously in quality (whereas if I broadcast it on this second screen with VlC it is perfect). I have the impression that resolume compresses the videos. I tried rendering in .mp4, in .mov with higher qualities but nothing happens...
Help
Re: Quality problem with output
4.8mm LED Panels are pretty low quality to begin with (I own over 1,200 of them...) when you are standing close to them. How does it look when you are 100' (33M) away?
Is your windows scaling set to 100%?
Quality is the same coming from your computers output so the problem lies within your connected devices. Make sure there is NO scaling happening on your connected devices (Not sure what processor you are using)
Moustikseb
When I view a video, without going through resolume, with windows media player or vlc, the quality is really excellent. The problem comes from a setting with resolume
Scaling perhaps?
Moustikseb
Scalling on resolume or on windows ?
either.
