Arena 7.16 Crash in MBP Apple M1 Max
flux-akira
Post by flux-akira »
Whether I download the installation package or turn on the automatic upgrade of arena, it will crash in version 7.16, but it will not happen after installing version 7.15. .
I put the crash data in the attached , someone can help :(
Code: Select all
Translated Report (Full Report Below)
Process:               Arena [61771]
Path:                  /Applications/Resolume Arena/Arena.app/Contents/MacOS/Arena
Identifier:            com.resolume.arena
Version:               7.16.0 (7.16.0.25503)
Code Type:             ARM-64 (Native)
Parent Process:        launchd [1]
User ID:               503
Date/Time:             2023-07-14 16:51:17.9080 +0800
OS Version:            macOS 13.4.1 (22F82)
Report Version:        12
Anonymous UUID:        38782E60-96E7-2DB3-14E7-F82A02893C5B
Sleep/Wake UUID:       0F7A5EB5-DE89-4737-95EA-F59A9A5E6D5C
Time Awake Since Boot: 360000 seconds
Time Since Wake:       280013 seconds
System Integrity Protection: enabled
Crashed Thread:        0  JUCE Message Thread  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes:       0x0000000000000001, 0x0000000000000000
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [61771]
VM Region Info: 0 is not in any region.  Bytes before following region: 4338188288
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      UNUSED SPACE AT START
      __TEXT                      102938000-105aa8000    [ 49.4M] r-x/r-x SM=COW  ...s/MacOS/Arena
Thread 0 Crashed:: JUCE Message Thread Dispatch queue: com.apple.main-thread
0   libsystem_platform.dylib      	       0x18be73e64 _platform_strlen + 4
1   libc++.1.dylib                	       0x18bd78fc0 std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>::assign(char const*) + 32
2   Arena                         	       0x104611a34 0x102938000 + 30251572
3   Arena                         	       0x103dd1d70 0x102938000 + 21601648
4   Arena                         	       0x102fe0adc 0x102938000 + 6982364
5   Arena                         	       0x10336a300 0x102938000 + 10691328
6   Arena                         	       0x10346bdd8 0x102938000 + 11746776
7   Arena                         	       0x10336a140 0x102938000 + 10690880
8   dyld                          	       0x18baeff28 start + 2236
Thread 1:
0   libsystem_pthread.dylib       	       0x18be42d8c start_wqthread + 0
Thread 2:
Thread 3:
Thread 4:
Thread 5:
0   libsystem_kernel.dylib        	       0x18be0b710 __psynch_cvwait + 8
1   libsystem_pthread.dylib       	       0x18be48574 _pthread_cond_wait + 1232
2   Arena                         	       0x1035cfeec 0x102938000 + 13205228
3   Arena                         	       0x1035cfbfc 0x102938000 + 13204476
4   Arena                         	       0x1041ac1c4 0x102938000 + 25641412
5   Arena                         	       0x1041ac140 0x102938000 + 25641280
6   libsystem_pthread.dylib       	       0x18be47fa8 _pthread_start + 148
7   libsystem_pthread.dylib       	       0x18be42da0 thread_start + 8
Thread 6:
0   libsystem_kernel.dylib        	       0x18be07f14 mach_msg2_trap + 8
1   libsystem_kernel.dylib        	       0x18be1a240 mach_msg2_internal + 80
2   libsystem_kernel.dylib        	       0x18be10b78 mach_msg_overwrite + 604
3   libsystem_kernel.dylib        	       0x18be08290 mach_msg + 24
4   CrashReporter                 	       0x10604c8ac exception_server_thread + 180
5   libsystem_pthread.dylib       	       0x18be47fa8 _pthread_start + 148
6   libsystem_pthread.dylib       	       0x18be42da0 thread_start + 8
Thread 7:: CVDisplayLink
1   libsystem_pthread.dylib       	       0x18be485a0 _pthread_cond_wait + 1276
2   CoreVideo                     	       0x193bd4c64 CVDisplayLink::waitUntil(unsigned long long) + 324
3   CoreVideo                     	       0x193bd3d34 CVDisplayLink::runIOThread() + 504
4   libsystem_pthread.dylib       	       0x18be47fa8 _pthread_start + 148
5   libsystem_pthread.dylib       	       0x18be42da0 thread_start + 8
Thread 8:
2   Arena                         	       0x104291554 0x102938000 + 26580308
3   Arena                         	       0x10428d2cc 0x102938000 + 26563276
4   Arena                         	       0x10468d128 0x102938000 + 30757160
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
flux-akira
Re: Arena 7.16 Crash in MBP Apple M1 Max
Code: Select all
Thread 16:
0   libsystem_kernel.dylib        	       0x18be0b50c __semwait_signal + 8
1   libsystem_c.dylib             	       0x18bcec2d0 nanosleep + 220
2   libc++.1.dylib                	       0x18bd7ea18 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84
3   Arena                         	       0x1041d0848 0x102938000 + 25790536
Thread 17:: caulk.messenger.shared:17
0   libsystem_kernel.dylib        	       0x18be07e90 semaphore_wait_trap + 8
1   caulk                         	       0x19547b024 caulk::semaphore::timed_wait(double) + 212
2   caulk                         	       0x19547aed8 caulk::concurrent::details::worker_thread::run() + 36
3   caulk                         	       0x19547abc8 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*>>>(void*) + 96
Thread 18:
3   Arena                         	       0x10456c4f4 0x102938000 + 29574388
Thread 19:
2   Arena                         	       0x104291228 0x102938000 + 26579496
3   Arena                         	       0x1046a36e4 0x102938000 + 30848740
Thread 20:
0   libobjc.A.dylib               	       0x18baac604 objc_release + 28
1   IOKit                         	       0x18efd1414 IOCFUnserializeBinary + 1852
2   IOKit                         	       0x18efd09b4 IORegistryEntryCreateCFProperties + 196
3   Arena                         	       0x1046a30f4 0x102938000 + 30847220
4   Arena                         	       0x1046a36a0 0x102938000 + 30848672
5   Arena                         	       0x10468d128 0x102938000 + 30757160
Thread 21:
Thread 22:
Thread 23:
3   Arena                         	       0x104630208 0x102938000 + 30376456
Thread 24:
Thread 0 crashed with ARM Thread State (64-bit):
    x0: 0x0000000000000000   x1: 0x0000000000000000   x2: 0xffffffffffffffe0   x3: 0x0000000130ba6fa0
    x4: 0x0000000130ba7000   x5: 0x0000000000000020   x6: 0x0000000000000001   x7: 0x0000000000000011
    x8: 0x0000000126376800   x9: 0x274ebae37fce0097  x10: 0x0000000000000008  x11: 0x0000000089021100
   x12: 0x0000000089021100  x13: 0x0000000089421100  x14: 0x00000000ffffffff  x15: 0x0000000089001100
   x16: 0x000000018be73e60  x17: 0x00000001eb93eb20  x18: 0x0000000000000000  x19: 0x0000000000000000
   x20: 0x000000016d4c63f0  x21: 0x0000000000000001  x22: 0x00000001263849f8  x23: 0x0000000105a1722e
   x24: 0x0000000105ca4ff0  x25: 0x0000000000000000  x26: 0x000000016d4c6470  x27: 0x000000012635b400
   x28: 0x0000000105a1723a   fp: 0x000000016d4c6380   lr: 0x000000018bd78fc0
    sp: 0x000000016d4c6370   pc: 0x000000018be73e64 cpsr: 0x60001000
   far: 0x0000000000000000  esr: 0x92000006 (Data Abort) byte read Translation fault
Binary Images:
       0x102938000 -        0x105aa7fff com.resolume.arena (7.16.0) <6c2c09a4-651b-3082-bdb0-b3e844038d63> /Applications/Resolume Arena/Arena.app/Contents/MacOS/Arena
       0x105f40000 -        0x105f4bfff libArtnet.dylib (*) <8db56a4f-18f3-3c13-8abe-25324255dc48> /Library/Application Support/Resolume/*/libArtnet.dylib
       0x1066c0000 -        0x106973fff libavfilter.8.dylib (*) <f535db08-a21a-336f-af1e-fe0112578214> /Library/Application Support/Resolume/*/libavfilter.8.dylib
       0x1063d8000 -        0x1065c7fff libavformat.59.dylib (*) <1e9b668f-4d32-3748-9d16-31e8ad0e87cb> /Library/Application Support/Resolume/*/libavformat.59.dylib
       0x1083b8000 -        0x108e7ffff libavcodec.59.dylib (*) <2d79b1ee-bf37-312d-9c70-5518ba7fe029> /Library/Application Support/Resolume/*/libavcodec.59.dylib
       0x106100000 -        0x106197fff libswscale.6.dylib (*) <a164c5a0-28d0-395f-a680-ab8d797f8e3c> /Library/Application Support/Resolume/*/libswscale.6.dylib
       0x1061b0000 -        0x106223fff libavutil.57.dylib (*) <e79ffe30-1559-33a2-9856-f75f93909e3f> /Library/Application Support/Resolume/*/libavutil.57.dylib
       0x106a0c000 -        0x106c6bfff libndi.dylib (*) <e827ab7e-91d7-3544-9144-3a38e5b0ad6d> /Library/Application Support/Resolume/*/libndi.dylib
       0x105f04000 -        0x105f13fff info.v002.Syphon (5) <2ca52af2-f35c-35d3-bb68-5a7531f8dca6> /Library/Application Support/Resolume/*/Syphon.framework/Versions/A/Syphon
       0x106618000 -        0x10665ffff org.sparkle-project.Sparkle (1.26.0) <0665d9d9-19bb-3f5a-9b90-aa9e1d1d4e7d> /Library/Application Support/Resolume/*/Sparkle.framework/Versions/A/Sparkle
       0x105ff4000 -        0x106017fff com.bugsplat.BugsplatMac (1.1) <275207d8-e30c-3f47-b728-e17cee29d152> /Library/Application Support/Resolume/*/BugsplatMac.framework/Versions/A/BugsplatMac
       0x105f90000 -        0x105f97fff libLTC.dylib (*) <4ccf7ad6-5b92-331c-a251-13ae0eb20f5f> /Library/Application Support/Resolume/*/libLTC.dylib
       0x10603c000 -        0x106063fff com.microsoft.CrashReporter (1.8.1) <fe2f59e1-3bb7-3300-94f4-505d25a75bfa> /Library/Application Support/Resolume/*/BugsplatMac.framework/Versions/A/Frameworks/CrashReporter.framework/Versions/A/CrashReporter
       0x11109c000 -        0x1110a7fff libobjc-trampolines.dylib (*) <570c31f7-94c6-3b86-ae44-1694db0a4bcd> /usr/lib/libobjc-trampolines.dylib
       0x11107c000 -        0x111083fff com.newtek.NDIVirtualCamera (2.0) <439bf840-9008-31db-bcf6-42b1046926b5> /Library/CoreMediaIO/*/NDIVirtualCamera.plugin/Contents/MacOS/NDIVirtualCamera
       0x113b28000 -        0x113d8bfff libndi_advanced.dylib (*) <ce453c8f-8123-3079-b948-a6bb44b9652a> /Library/CoreMediaIO/*/NDIVirtualCamera.plugin/Contents/Frameworks/libndi_advanced.dylib
       0x112088000 -        0x112097fff com.obsproject.mac-dal-plugin (28.1.2) <5f9f1e96-ec91-3247-aaae-9227cdbd8714> /Library/CoreMediaIO/*/obs-mac-virtualcam.plugin/Contents/MacOS/obs-mac-virtualcam
       0x1121f8000 -        0x112233fff com.newtek.cmio.DAL.NDI (1.0.117928) <90f26f36-6c46-3cfa-820c-2a26f7105351> /Library/CoreMediaIO/*/NDIVideoOut.plugin/Contents/MacOS/NDIVideoOut
       0x11229c000 -        0x1122e3fff com.apple.cmio.DAL.VDC-4 (810.0) <ee11b407-40e7-398e-9709-290559bdcd25> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/Resources/VDC.plugin/Contents/MacOS/VDC
       0x112310000 -        0x11237bfff com.apple.AppleMetalOpenGLRenderer (1.0) <01596a35-894c-3104-8314-40d3c08f18ca> /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer
       0x18be73000 -        0x18be79ffb libsystem_platform.dylib (*) <f80c6971-c080-31f5-ab6e-be01311154af> /usr/lib/system/libsystem_platform.dylib
       0x18bd5e000 -        0x18bdeaff7 libc++.1.dylib (*) <54e8fbe1-df0d-33a2-b8fa-356565c12929> /usr/lib/libc++.1.dylib
       0x18baea000 -        0x18bb78553 dyld (*) <2237410f-d39c-30ce-9a94-13aacb66b766> /usr/lib/dyld
       0x18be41000 -        0x18be4dfff libsystem_pthread.dylib (*) <46d35233-a051-3f4f-bba4-ba56dddc4d1a> /usr/lib/system/libsystem_pthread.dylib
       0x18be07000 -        0x18be40fe7 libsystem_kernel.dylib (*) <34a49b54-82b2-37a1-9314-f6a4a2bb3ff8> /usr/lib/system/libsystem_kernel.dylib
       0x193bd1000 -        0x193c32fff com.apple.CoreVideo (1.8) <23a7c243-4552-3f81-b4f7-b9723ee40a45> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
       0x18bcdf000 -        0x18bd5dff7 libsystem_c.dylib (*) <95a70e20-1df3-3ddf-900c-315ed0b2c067> /usr/lib/system/libsystem_c.dylib
       0x195479000 -        0x1954a1fff com.apple.audio.caulk (1.0) <d793971d-25be-323d-83a4-cc72fadafe8d> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
       0x18baa4000 -        0x18bae9f3f libobjc.A.dylib (*) <5beafa2b-3af4-3ed2-b054-1f58a7c851ef> /usr/lib/libobjc.A.dylib
       0x18efcd000 -        0x18f0a7fff com.apple.framework.IOKit (2.0.2) <5299a9d2-e26e-3368-ad3a-a0a1eccc0310> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.2G resident=0K(0%) swapped_out_or_unallocated=1.2G(100%)
Writable regions: Total=527.9M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=527.9M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Activity Tracing                   256K        1
ColorSync                          480K       24
CoreAnimation                       48K        3
CoreGraphics                        64K        4
CoreServices                       208K        1
Dispatch continuations            80.0M        1
Foundation                          16K        1
Kernel Alloc Once                   32K        1
MALLOC                           121.6M       45
MALLOC guard page                  192K       11
MALLOC_MEDIUM (reserved)          96.0M        1         reserved VM address space (unallocated)
OpenGL GLSL                        384K        5
STACK GUARD                       56.4M       25
Stack                             20.7M       25
VM_ALLOCATE                      198.5M       37
__AUTH                             862K      208
__AUTH_CONST                      17.9M      390
__CTF                               824        1
__DATA                            17.6M      401
__DATA_CONST                      20.9M      410
__DATA_DIRTY                       986K      131
__FONT_DATA                        2352        1
__GLSLBUILTINS                    5174K        1
__LINKEDIT                       804.9M       21
__OBJC_RO                         66.3M        1
__OBJC_RW                         2011K        1
__TEXT                           458.5M      429
dyld private memory                272K        2
mapped file                      132.2M      166
shared memory                      864K       14
TOTAL                              2.1G     2362
TOTAL, minus reserved VM space     2.0G     2362
Full Report
{"app_name":"Arena","timestamp":"2023-07-14 16:51:18.00 +0800","app_version":"7.16.0","slice_uuid":"6c2c09a4-651b-3082-bdb0-b3e844038d63","build_version":"7.16.0.25503","platform":1,"bundleID":"com.resolume.arena","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 13.4.1 (22F82)","roots_installed":0,"name":"Arena","incident_id":"06918840-DAA8-4446-BEE0-05078F040A9F"}
  "uptime" : 360000,
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 503,
  "deployVersion" : 210,
  "modelCode" : "MacBookPro18,4",
  "coalitionID" : 30105,
  "osVersion" : {
    "train" : "macOS 13.4.1",
    "build" : "22F82",
    "releaseType" : "User"
  "captureTime" : "2023-07-14 16:51:17.9080 +0800",
  "incident" : "06918840-DAA8-4446-BEE0-05078F040A9F",
  "pid" : 61771,
  "translated" : false,
  "cpuType" : "ARM-64",
  "roots_installed" : 0,
  "bug_type" : "309",
  "procLaunch" : "2023-07-14 16:51:12.2588 +0800",
  "procStartAbsTime" : 8713908320834,
  "procExitAbsTime" : 8714043046979,
  "procName" : "Arena",
  "procPath" : "\/Applications\/Resolume Arena\/Arena.app\/Contents\/MacOS\/Arena",
  "bundleInfo" : {"CFBundleShortVersionString":"7.16.0","CFBundleVersion":"7.16.0.25503","CFBundleIdentifier":"com.resolume.arena"},
  "storeInfo" : {"deviceIdentifierForVendor":"E5708A07-F34A-5A4B-9A68-6B0CE996A56A","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "com.resolume.arena",
  "crashReporterKey" : "38782E60-96E7-2DB3-14E7-F82A02893C5B",
  "codeSigningID" : "com.resolume.arena",
  "codeSigningTeamID" : "Z9Y8N6Q4L8",
  "codeSigningFlags" : 570495745,
  "codeSigningValidationCategory" : 6,
  "codeSigningTrustLevel" : 0,
  "wakeTime" : 280013,
  "sleepWakeUUID" : "0F7A5EB5-DE89-4737-95EA-F59A9A5E6D5C",
  "sip" : "enabled",
  "vmRegionInfo" : "0 is not in any region.  Bytes before following region: 4338188288\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      102938000-105aa8000    [ 49.4M] r-x\/r-x SM=COW  ...s\/MacOS\/Arena",
  "exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000000"},
  "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":61771},
  "vmregioninfo" : "0 is not in any region.  Bytes before following region: 4338188288\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      102938000-105aa8000    [ 49.4M] r-x\/r-x SM=COW  ...s\/MacOS\/Arena",
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 0,
  "threads" : [{"triggered":true,"id":3882381,"threadState":{"x":[{"value":0},{"value":0},{"value":18446744073709551584},{"value":5112491936},{"value":5112492032},{"value":32},{"value":1},{"value":17},{"value":4936132608},{"value":2832406701927170199},{"value":8},{"value":2298614016},{"value":2298614016},{"value":2302808320},{"value":4294967295},{"value":2298482944},{"value":6642155104,"symbolLocation":0,"symbol":"_platform_strlen"},{"value":8247307040},{"value":0},{"value":0},{"value":6128690160},{"value":1},{"value":4936190456},{"value":4389433902},{"value":4392112112},{"value":0},{"value":6128690288},{"value":4936020992},{"value":4389433914}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6641127360},"cpsr":{"value":1610616832},"fp":{"value":6128690048},"sp":{"value":6128690032},"esr":{"value":2449473542,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":6642155108,"matchesCrashFrame":1},"far":{"value":0}},"name":"JUCE Message Thread","queue":"com.apple.main-thread","frames":[{"imageOffset":3684,"symbol":"_platform_strlen","symbolLocation":4,"imageIndex":20},{"imageOffset":110528,"symbol":"std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>::assign(char const*)","symbolLocation":32,"imageIndex":21},{"imageOffset":30251572,"imageIndex":0},{"imageOffset":21601648,"imageIndex":0},{"imageOffset":6982364,"imageIndex":0},{"imageOffset":10691328,"imageIndex":0},{"imageOffset":11746776,"imageIndex":0},{"imageOffset":10690880,"imageIndex":0},{"imageOffset":24360,"symbol":"start","symbolLocation":2236,"imageIndex":22}]},{"id":3882627,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":23}]},{"id":3882628,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":23}]},{"id":3882633,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":23}]},{"id":3882634,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":23}]},{"id":3882647,"frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":23},{"imageOffset":13205228,"imageIndex":0},{"imageOffset":13204476,"imageIndex":0},{"imageOffset":25641412,"imageIndex":0},{"imageOffset":25641280,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3882651,"frames":[{"imageOffset":3860,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":24},{"imageOffset":78400,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":24},{"imageOffset":39800,"symbol":"mach_msg_overwrite","symbolLocation":604,"imageIndex":24},{"imageOffset":4752,"symbol":"mach_msg","symbolLocation":24,"imageIndex":24},{"imageOffset":67756,"symbol":"exception_server_thread","symbolLocation":180,"imageIndex":12},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3882653,"name":"CVDisplayLink","frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30112,"symbol":"_pthread_cond_wait","symbolLocation":1276,"imageIndex":23},{"imageOffset":15460,"symbol":"CVDisplayLink::waitUntil(unsigned long long)","symbolLocation":324,"imageIndex":25},{"imageOffset":11572,"symbol":"CVDisplayLink::runIOThread()","symbolLocation":504,"imageIndex":25},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3882654,"frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":23},{"imageOffset":26580308,"imageIndex":0},{"imageOffset":26563276,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3882655,"frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":23},{"imageOffset":26580308,"imageIndex":0},{"imageOffset":26563276,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3882656,"frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":23},{"imageOffset":26580308,"imageIndex":0},{"imageOffset":26563276,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3882657,"frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":23},{"imageOffset":26580308,"imageIndex":0},{"imageOffset":26563276,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3882658,"frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":23},{"imageOffset":26580308,"imageIndex":0},{"imageOffset":26563276,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3882659,"frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":23},{"imageOffset":26580308,"imageIndex":0},{"imageOffset":26563276,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3882660,"frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":23},{"imageOffset":26580308,"imageIndex":0},{"imageOffset":26563276,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3882661,"frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":23},{"imageOffset":26580308,"imageIndex":0},{"imageOffset":26563276,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3882662,"frames":[{"imageOffset":17676,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":24},{"imageOffset":53968,"symbol":"nanosleep","symbolLocation":220,"imageIndex":26},{"imageOffset":133656,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":21},{"imageOffset":25790536,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3882667,"name":"caulk.messenger.shared:17","frames":[{"imageOffset":3728,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":24},{"imageOffset":8228,"symbol":"caulk::semaphore::timed_wait(double)","symbolLocation":212,"imageIndex":27},{"imageOffset":7896,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":36,"imageIndex":27},{"imageOffset":7112,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*>>>(void*)","symbolLocation":96,"imageIndex":27},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3882999,"frames":[{"imageOffset":17676,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":24},{"imageOffset":53968,"symbol":"nanosleep","symbolLocation":220,"imageIndex":26},{"imageOffset":133656,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":21},{"imageOffset":29574388,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3883000,"frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":23},{"imageOffset":26579496,"imageIndex":0},{"imageOffset":30848740,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3883004,"frames":[{"imageOffset":34308,"symbol":"objc_release","symbolLocation":28,"imageIndex":28},{"imageOffset":17428,"symbol":"IOCFUnserializeBinary","symbolLocation":1852,"imageIndex":29},{"imageOffset":14772,"symbol":"IORegistryEntryCreateCFProperties","symbolLocation":196,"imageIndex":29},{"imageOffset":30847220,"imageIndex":0},{"imageOffset":30848672,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3883006,"frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":23},{"imageOffset":26579496,"imageIndex":0},{"imageOffset":30848740,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3883007,"frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":23},{"imageOffset":26579496,"imageIndex":0},{"imageOffset":30848740,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3883008,"frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":24},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":23},{"imageOffset":26579496,"imageIndex":0},{"imageOffset":30376456,"imageIndex":0},{"imageOffset":30757160,"imageIndex":0},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":23},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":23}]},{"id":3883040,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":23}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "arm64",
    "base" : 4338188288,
    "CFBundleShortVersionString" : "7.16.0",
    "CFBundleIdentifier" : "com.resolume.arena",
    "size" : 51838976,
    "uuid" : "6c2c09a4-651b-3082-bdb0-b3e844038d63",
    "path" : "\/Applications\/Resolume Arena\/Arena.app\/Contents\/MacOS\/Arena",
    "name" : "Arena",
    "CFBundleVersion" : "7.16.0.25503"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4394844160,
    "size" : 49152,
    "uuid" : "8db56a4f-18f3-3c13-8abe-25324255dc48",
    "path" : "\/Library\/Application Support\/Resolume\/*\/libArtnet.dylib",
    "name" : "libArtnet.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4402708480,
    "size" : 2834432,
    "uuid" : "f535db08-a21a-336f-af1e-fe0112578214",
    "path" : "\/Library\/Application Support\/Resolume\/*\/libavfilter.8.dylib",
    "name" : "libavfilter.8.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4399661056,
    "size" : 2031616,
    "uuid" : "1e9b668f-4d32-3748-9d16-31e8ad0e87cb",
    "path" : "\/Library\/Application Support\/Resolume\/*\/libavformat.59.dylib",
    "name" : "libavformat.59.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4433084416,
    "size" : 11304960,
    "uuid" : "2d79b1ee-bf37-312d-9c70-5518ba7fe029",
    "path" : "\/Library\/Application Support\/Resolume\/*\/libavcodec.59.dylib",
    "name" : "libavcodec.59.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4396679168,
    "size" : 622592,
    "uuid" : "a164c5a0-28d0-395f-a680-ab8d797f8e3c",
    "path" : "\/Library\/Application Support\/Resolume\/*\/libswscale.6.dylib",
    "name" : "libswscale.6.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4397400064,
    "size" : 475136,
    "uuid" : "e79ffe30-1559-33a2-9856-f75f93909e3f",
    "path" : "\/Library\/Application Support\/Resolume\/*\/libavutil.57.dylib",
    "name" : "libavutil.57.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4406165504,
    "size" : 2490368,
    "uuid" : "e827ab7e-91d7-3544-9144-3a38e5b0ad6d",
    "path" : "\/Library\/Application Support\/Resolume\/*\/libndi.dylib",
    "name" : "libndi.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4394598400,
    "CFBundleShortVersionString" : "5",
    "CFBundleIdentifier" : "info.v002.Syphon",
    "size" : 65536,
    "uuid" : "2ca52af2-f35c-35d3-bb68-5a7531f8dca6",
    "path" : "\/Library\/Application Support\/Resolume\/*\/Syphon.framework\/Versions\/A\/Syphon",
    "name" : "Syphon",
    "CFBundleVersion" : "5"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4402020352,
    "CFBundleShortVersionString" : "1.26.0",
    "CFBundleIdentifier" : "org.sparkle-project.Sparkle",
    "size" : 294912,
    "uuid" : "0665d9d9-19bb-3f5a-9b90-aa9e1d1d4e7d",
    "path" : "\/Library\/Application Support\/Resolume\/*\/Sparkle.framework\/Versions\/A\/Sparkle",
    "name" : "Sparkle",
    "CFBundleVersion" : "1.26.0"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4395581440,
    "CFBundleShortVersionString" : "1.1",
    "CFBundleIdentifier" : "com.bugsplat.BugsplatMac",
    "size" : 147456,
    "uuid" : "275207d8-e30c-3f47-b728-e17cee29d152",
    "path" : "\/Library\/Application Support\/Resolume\/*\/BugsplatMac.framework\/Versions\/A\/BugsplatMac",
    "name" : "BugsplatMac",
    "CFBundleVersion" : "1"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4395171840,
    "size" : 32768,
    "uuid" : "4ccf7ad6-5b92-331c-a251-13ae0eb20f5f",
    "path" : "\/Library\/Application Support\/Resolume\/*\/libLTC.dylib",
    "name" : "libLTC.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4395876352,
    "CFBundleShortVersionString" : "1.8.1",
    "CFBundleIdentifier" : "com.microsoft.CrashReporter",
    "size" : 163840,
    "uuid" : "fe2f59e1-3bb7-3300-94f4-505d25a75bfa",
    "path" : "\/Library\/Application Support\/Resolume\/*\/BugsplatMac.framework\/Versions\/A\/Frameworks\/CrashReporter.framework\/Versions\/A\/CrashReporter",
    "name" : "CrashReporter",
    "CFBundleVersion" : "1.8.1"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4580818944,
    "size" : 49152,
    "uuid" : "570c31f7-94c6-3b86-ae44-1694db0a4bcd",
    "path" : "\/usr\/lib\/libobjc-trampolines.dylib",
    "name" : "libobjc-trampolines.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4580687872,
    "CFBundleShortVersionString" : "2.0",
    "CFBundleIdentifier" : "com.newtek.NDIVirtualCamera",
    "size" : 32768,
    "uuid" : "439bf840-9008-31db-bcf6-42b1046926b5",
    "path" : "\/Library\/CoreMediaIO\/*\/NDIVirtualCamera.plugin\/Contents\/MacOS\/NDIVirtualCamera",
    "name" : "NDIVirtualCamera",
    "CFBundleVersion" : "2"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4625432576,
    "size" : 2506752,
    "uuid" : "ce453c8f-8123-3079-b948-a6bb44b9652a",
    "path" : "\/Library\/CoreMediaIO\/*\/NDIVirtualCamera.plugin\/Contents\/Frameworks\/libndi_advanced.dylib",
    "name" : "libndi_advanced.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4597514240,
    "CFBundleShortVersionString" : "28.1.2",
    "CFBundleIdentifier" : "com.obsproject.mac-dal-plugin",
    "size" : 65536,
    "uuid" : "5f9f1e96-ec91-3247-aaae-9227cdbd8714",
    "path" : "\/Library\/CoreMediaIO\/*\/obs-mac-virtualcam.plugin\/Contents\/MacOS\/obs-mac-virtualcam",
    "name" : "obs-mac-virtualcam",
    "CFBundleVersion" : "3401132301"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4599021568,
    "CFBundleShortVersionString" : "1.0.117928",
    "CFBundleIdentifier" : "com.newtek.cmio.DAL.NDI",
    "size" : 245760,
    "uuid" : "90f26f36-6c46-3cfa-820c-2a26f7105351",
    "path" : "\/Library\/CoreMediaIO\/*\/NDIVideoOut.plugin\/Contents\/MacOS\/NDIVideoOut",
    "name" : "NDIVideoOut",
    "CFBundleVersion" : "1.0"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4599693312,
    "CFBundleShortVersionString" : "810.0",
    "CFBundleIdentifier" : "com.apple.cmio.DAL.VDC-4",
    "size" : 294912,
    "uuid" : "ee11b407-40e7-398e-9709-290559bdcd25",
    "path" : "\/System\/Library\/Frameworks\/CoreMediaIO.framework\/Versions\/A\/Resources\/VDC.plugin\/Contents\/MacOS\/VDC",
    "name" : "VDC",
    "CFBundleVersion" : "378.7"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4600168448,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.apple.AppleMetalOpenGLRenderer",
    "size" : 442368,
    "uuid" : "01596a35-894c-3104-8314-40d3c08f18ca",
    "path" : "\/System\/Library\/Extensions\/AppleMetalOpenGLRenderer.bundle\/Contents\/MacOS\/AppleMetalOpenGLRenderer",
    "name" : "AppleMetalOpenGLRenderer",
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6642151424,
    "size" : 28668,
    "uuid" : "f80c6971-c080-31f5-ab6e-be01311154af",
    "path" : "\/usr\/lib\/system\/libsystem_platform.dylib",
    "name" : "libsystem_platform.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6641016832,
    "size" : 577528,
    "uuid" : "54e8fbe1-df0d-33a2-b8fa-356565c12929",
    "path" : "\/usr\/lib\/libc++.1.dylib",
    "name" : "libc++.1.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6638444544,
    "size" : 582996,
    "uuid" : "2237410f-d39c-30ce-9a94-13aacb66b766",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6641946624,
    "size" : 53248,
    "uuid" : "46d35233-a051-3f4f-bba4-ba56dddc4d1a",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6641709056,
    "size" : 237544,
    "uuid" : "34a49b54-82b2-37a1-9314-f6a4a2bb3ff8",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6773608448,
    "CFBundleShortVersionString" : "1.8",
    "CFBundleIdentifier" : "com.apple.CoreVideo",
    "size" : 401408,
    "uuid" : "23a7c243-4552-3f81-b4f7-b9723ee40a45",
    "path" : "\/System\/Library\/Frameworks\/CoreVideo.framework\/Versions\/A\/CoreVideo",
    "name" : "CoreVideo",
    "CFBundleVersion" : "555.1"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6640496640,
    "size" : 520184,
    "uuid" : "95a70e20-1df3-3ddf-900c-315ed0b2c067",
    "path" : "\/usr\/lib\/system\/libsystem_c.dylib",
    "name" : "libsystem_c.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6799462400,
    "CFBundleIdentifier" : "com.apple.audio.caulk",
    "size" : 167936,
    "uuid" : "d793971d-25be-323d-83a4-cc72fadafe8d",
    "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk",
    "name" : "caulk"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6638157824,
    "size" : 286528,
    "uuid" : "5beafa2b-3af4-3ed2-b054-1f58a7c851ef",
    "path" : "\/usr\/lib\/libobjc.A.dylib",
    "name" : "libobjc.A.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6693900288,
    "CFBundleShortVersionString" : "2.0.2",
    "CFBundleIdentifier" : "com.apple.framework.IOKit",
    "size" : 897024,
    "uuid" : "5299a9d2-e26e-3368-ad3a-a0a1eccc0310",
    "path" : "\/System\/Library\/Frameworks\/IOKit.framework\/Versions\/A\/IOKit",
    "name" : "IOKit"
  "sharedCache" : {
  "base" : 6637780992,
  "size" : 3551641600,
  "uuid" : "be59bb71-7b69-3efc-86a8-5625a077ae2e"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.2G resident=0K(0%) swapped_out_or_unallocated=1.2G(100%)\nWritable regions: Total=527.9M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=527.9M(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nActivity Tracing                   256K        1 \nColorSync                          480K       24 \nCoreAnimation                       48K        3 \nCoreGraphics                        64K        4 \nCoreServices                       208K        1 \nDispatch continuations            80.0M        1 \nFoundation                          16K        1 \nKernel Alloc Once                   32K        1 \nMALLOC                           121.6M       45 \nMALLOC guard page                  192K       11 \nMALLOC_MEDIUM (reserved)          96.0M        1         reserved VM address space (unallocated)\nOpenGL GLSL                        384K        5 \nSTACK GUARD                       56.4M       25 \nStack                             20.7M       25 \nVM_ALLOCATE                      198.5M       37 \n__AUTH                             862K      208 \n__AUTH_CONST                      17.9M      390 \n__CTF                               824        1 \n__DATA                            17.6M      401 \n__DATA_CONST                      20.9M      410 \n__DATA_DIRTY                       986K      131 \n__FONT_DATA                        2352        1 \n__GLSLBUILTINS                    5174K        1 \n__LINKEDIT                       804.9M       21 \n__OBJC_RO                         66.3M        1 \n__OBJC_RW                         2011K        1 \n__TEXT                           458.5M      429 \ndyld private memory                272K        2 \nmapped file                      132.2M      166 \nshared memory                      864K       14 \n===========                     =======  ======= \nTOTAL                              2.1G     2362 \nTOTAL, minus reserved VM space     2.0G     2362 \n",
  "legacyInfo" : {
  "threadTriggered" : {
    "name" : "JUCE Message Thread",
    "queue" : "com.apple.main-thread"
  "logWritingSignature" : "20c8d21cbc6f569ff2c3c02a18a4d8e1ed4bfe1f",
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "63508950b3714d3622fc77f7",
      "factorPackIds" : {
        "SIRI_MEMORY_SYNC_CONFIG" : "63508beab3714d3622fc7808"
      "deploymentId" : 240000004
      "rolloutId" : "639124e81d92412bfb4880b3",
      "factorPackIds" : {
  "experiments" : [
Model: MacBookPro18,4, BootROM 8422.121.1, proc 10:8:2 processors, 64 GB, SMC
Graphics: Apple M1 Max, Apple M1 Max, Built-In
Display: Color LCD, 3024 x 1964 Retina, Main, MirrorOff, Online
Display: Mi TV, 1920 x 1080 (1080p FHD - Full High Definition), MirrorOff, Online
Display: DELL U2415, 1920 x 1200 (WUXGA - Widescreen Ultra eXtended Graphics Array), MirrorOff, Online
Memory Module: LPDDR5, Hynix
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4387), wl0: Apr  7 2023 15:18:26 version 20.96.28.1.8.7.146 FWID 01-aff1b48a
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: KICKSTAR DESK HUB, Ethernet, en46
Network Service: CalDIGI HUB, Ethernet, en30
PCI Card: pci1b73,1100, USB eXtensible Host Controller, Thunderbolt@5,0,0
PCI Card: pci1b21,1242, USB eXtensible Host Controller, Thunderbolt@4,0,0
PCI Card: pci1b73,1100, USB eXtensible Host Controller, Thunderbolt@6,0,0
PCI Card: ethernet, Ethernet Controller, Thunderbolt@3,0,0
USB Device: USB31Bus
USB Device: USB3.1 Hub
USB Device: USB3.0 Hub
USB Device: USB 10/100/1000 LAN
USB Device: G-DRIVE mobile SSD R-Series
USB Device: NS1081
USB Device: USB2.0 Hub
USB Device: USB Billboard Device
USB Device: USB 2.0 BILLBOARD
USB Device: USB30Bus
USB Device: Card Reader
USB Device: Razer Goliathus Extended Chroma
USB Device: USB Serial
USB Device: CodeMeter-Stick
USB Device: Flash Disk
USB Device: CalDigit Thunderbolt 3 Audio
USB Device: SSL 2+
USB Device: Innov8
Thunderbolt Bus: MacBook Pro, Apple Inc.
Thunderbolt Device: TS3 Plus, CalDigit, Inc., 1, 35.1
Could you please use the crash reporter dialog that pops up after the crash to submit a crash report?
That way we get lot more detailed information about what went wrong exactly.
Don't forget to fill out your email address, so we know it came from you ;)
flux-akira
ok thought i was on tour, i'll install sometime and then use the crash report thanks :D
