Timecode and audio
Lincoln Lee
Timecode and audio
Post by Lincoln Lee »
Hello, I had an issue where i can let timecode trigger a clip but then I lose the audio from the clip itself.
Is there a way I can still let timecode trigger my clip and still play the video audio?
赵云飞
回复:时间码和音频
Post by 赵云飞 »
External plugins
Re: Timecode and audio
Audio + Video clips can't be synced to SMPTE currently, so even if you can get them triggered from third party app, they will probably drift from the TC.
A good solution would be to have the Audio of the clip play in the same software which provides the time code.
Zoltán wrote: Wed Aug 02, 2023 10:34 Audio + Video clips can't be synced to SMPTE currently, so even if you can get them triggered from third party app, they will probably drift from the TC.
^THIS 100%
Resolume for Video and Ableton for LTC and Audio ;)
