A smarter sound EQ
FractalMan
A smarter sound EQ
Post by FractalMan »
Love the software, but for me it would be much more functional if the (dynamic moving) equalizer in the sound-activated parameter window had a grid with numerical values. The long row of segmented lines doesn't tell me what frequency any of them are. Then I could use that as a reference in other apps.
Re: A smarter sound EQ
https://pixelparty.gumroad.com/l/beat_d ... ixel_party
^ A nice side app to do more advanced audio to animation processing.
fhughes
Post by fhughes »
One issue I've found with the software is that when using some filters, such as the high pass or low pass filter, the audio seems to "break up" slightly. Is there any way to fix this?
fhughes wrote: Wed Aug 02, 2023 07:49 One issue I've found with the software is that when using some filters, such as the high pass or low pass filter, the audio seems to "break up" slightly. Is there any way to fix this?
You would need to request a pfl/afl mode for audio animations.
fhughes wrote: Wed Aug 02, 2023 07:49 audio seems to "break up" slightly. Is there any way to fix this?
like crackling?
Try increasing the audio buffer size in preferences.
