Disabling HT boosts up resolume?
Anonymous
Post by Anonymous »
As all of you know resolume does not support dual core, therefore doesn't use the second virtual cpu provided by the HT technology.
Has anyone (or simply the developers) done any tests about HT enabled versus HT disabled? I've tried but am not really capable to see any difference.
Thanks,
JaKo
we do not have a computer with a cpu that does HT so unfornunately we have not tried to see it there is any noticable difference.
but the have been some threads baout htis in the past so there is some expertise here in the forum.
DrMazoola
Post by DrMazoola »
As best as I can tell, it *does* boost performance slightly. Unfortunately, on my system it also screws up MIDI input -- MIDI signals are delayed or lost. This has previously been reported by others (Bunniboi, perhaps?).
VJzoo
Post by VJzoo »
yes we did have some probs with it, but now we run PM's which a realy good, nice battery life and dont melt stuff like a H-Threded P4 :D
Meno
Post by Meno »
According to Kyle on VJforums.com...
"It is recommended to turn Hyperthreading off if you r processor supports it because it does not allow any application to take the full 100% of the CPU."
You can find the thread HERE
Hope this helps,
Meno
Anonymous
Post by Anonymous »
Is the future version of Resolume will include a dual-core optimisation ???
