How to add multiple monitors to resolume
ShowTechnics
hi guys. Maybe anyone knows how to make for instance 3 monitors instead of usual 2 monitors 1 for prewiev and one for composition
Re: How to add multiple monitors to resolume
This should be in the 'General/How Do I' channel.
If you right click on a monitor you can then click duplicate, then you can change the new monitor to display whatever you like, and from there you can also move it to a different location and resize as needed.
