clip trigger delay
rawdesigns
clip trigger delay
Post by rawdesigns »
was wondering if i could trigger a clip and set the delay for it to start playing by whatever amount of seconds i choose?
tijnisfijn
Re: clip trigger delay
Post by tijnisfijn »
I made a video for you showing how this is easily done. You have to add a extra solid source though.
Hope this helps you out. If it's not clear or you have any more questions, let me know...
rawdesigns
this is amazing i dont know why i didnt think of that i use the same concept to randomly trigger a clip on the layer. thank you!
edwin
Post by edwin »
There is also a 'blank' source, so yo do not need to change the color first. That was added especially situations like this.
rawdesigns
is it possible to do the following...
While a clip is playing set a timer for that clip to close. Not play another clip like a blank clip but to actually close the clip or group or layer?
tijnisfijn
what do you mean with close? like clear the clip from the layer?
rawdesigns
Yes to clear the clip
