Hello bonjour,
After installing Resolume Avenue last version 7.17, I have a problem using ASIO Audio driver.
In the AUDIO preference, after selecting a ASIO driver, and a master out channel, everything works fine.
After quitting and re opening Avenue, it looks like the preference were not saved, and no audio.
If I reselect the audio Output device in the list, "Focusrite USB ASIO3 in my case, and other audio parameters , it work fine,..... and lost again if I quit.
Note : If i select a directSound Driver, preferences are saved
config : windows 10, with focusrite scarlet 4i4 last drivers.
It was ok on the same PC with last resomume version.
Any Idea ?
thanks in advance,
Pascal
7.17 - loosing AUDIO ASIO Préferences after restrart.
Re: 7.17 - loosing AUDIO ASIO Préferences after restrart.
7.17.1 just installed.
Audio preferences are saved, now.
Merciiiiiiiiiiiiiiiiiii
