Disfunctional Shortcuts Window
Phlux
Post by Phlux »
Unable to navigate to specific Midi messages for editing.
The Scroll-Bar Jumps to top whenever I attempt to select a message I've found.
If I attempt to scroll by using the DOWN arrow key on my keyboard, it works for a short time, but the directory window eventually stops following along.
I took the time to recorded a screenshot, upload, and articulate in this post. Please notify me when it's fixed, as this functionality is currently unworkable:
https://vimeo.com/865539219
ALSO, Not all midi notes are getting sorted properly. For example "2/CC11" is not being sequenced anywhere near the following group: "9/CC11, 10/CC11, 11/CC11"
After experimenting with it, I notice that "Target", "input" and "Output" parameters are all influencing the sort of the XML file, such that it interferes with the ability to sort purely by the MIDI message.
The goal here is simply to be aware of what a specific controller knob is mapped to, and then edit or delete the map.
Re: Disfunctional Shortcuts Window
Could you attach the composition, and shortcut preset you use?
