Unable to see all capture channels.
JanneFIN
Post by JanneFIN »
Hello. Im using AJA Kona HDMI Capture card, with 4 HDMI inputs. but Resolume recognice only inputs 1,3 and 4. So the Input 2 does not detect. I have used everything from different cables. to splitter splitting exact same signal to all of the inputs. Resolume just doesnt want to see input 2. In AJA software, i can see ALL inputs. Also when i Use OBS. it can see ALL of the inputs no problem. What can cause this in Resolume???
Re: Unable to see all capture channels.
I see we have been in touch with you about this a few months ago via mail, haven't got a reply there ;)
Do you maybe have channel 2 active as output in the Advanced output?
gschellhas@imsts.com
Post by gschellhas@imsts.com »
I too am experiencing the same issue.
Resolume: 7.17.3
Mac Rack Pro
Apple M2 Ultra
Ventura 13.5
AJA Kona HDMI Card FW: 16.2.5.2
NTV2 SDK Version: 16.2.5
AJA Software Installer Vesrsion: 16.2.5.4
AJA Control Panel App Version: 16.2.5.4
Library Extensions Version: 16.2.5
JanneFIN
Post by JanneFIN »
The Aja Kona HDMI is input only. so there is no second channel assigned as output
System spec:
AMD Ryzen Threadripper PRO 3955WX
RTX A4000
W11
What's the resolution you're trying to capture?
JanneFIN
Post by JanneFIN »
1080p@50 what we usually capture.
Could you give this a try with the 7.22 release?
