Mac studio ultra
Prabodhananjaya
Mac studio ultra
Hi
any one using Mac Studio ultra for arena? What about the experience with that? Thanks
philmcrackin
Re: Mac studio ultra
there's benchmarks at the bottom of this thread: viewtopic.php?p=91407
So Resolume works well with the Apple M2s. Is there any reason to expect it not to also work well with the new M3s? They look incredibly powerful, with up to 128GB of integrated memory on the Max model.
Luisgoinsane
I would not recommend it because if you need to use 2 outputs together to make a big screen the outputs will be out of sync
I've used in festival and corporate events four times, Resolume perfoming great, what I am always struggling is that you need to have with you a converter, adapter and edid manager, hdcp killer. because there could always something that doesn't work as expected especially with a led processor or a graphic mixer like barco s2 or analog way aquilon (with mac in general).
Just an example, the built in hdmi port doesn't worked as expected, blacking out from time to time, usb-c hdmi adapter worked like charm (the unit was sent to apple care but didn't find any issues).
So be prepared
ps I am a big mac fan, usually since 2002 but I always have a pc as back-up
So be prepared
