Dot Orange MacOs Monterey
tedosavac
Post by tedosavac »
Hello,
I asked the question on this forum because I searched but I found no solution to my problem. Especially since I know that many people have the same problems as me.
This is the famous orange dot on MacOs Monterey.
For those who don't know, an orange dot appears at the top right on the video output when using Arena with a sound card for example.
Has the Resolume team found a solution?
Is there a way to make it disappear?
Because software like "Yellow dot" no longer works after the latest updates.
I'm open to all the ideas.
THANKS
Online
Christoph
Re: Dot Orange MacOs Monterey
Post by Christoph »
Have you tried this one?
https://github.com/cormiertyshawn895/Re ... torUtility
Worked fine for me on Ventura and Monterey.
Anne Gentenaar
Post by Anne Gentenaar »
Any idea how this would work on Sonoma? I cant find the terminal when I start up in recovery mode...
Update: for anyone have the same issue, I solved it with this one: https://support.apple.com/nl-nl/118449
Online
Christoph
Post by Christoph »
Since Sonoma 14.4 you could use these steps from Apple directly, so you shouldn't need any third-party tools anymore:
https://support.apple.com/en-gb/118449
Anne Gentenaar
Great thanks!
