Educational License
fraannk
Educational License
Post by fraannk »
What happens to an Educational license, when I am no longer studying? Is it then just a normal license I can extend with normal non-education prices?
Re: Educational License
Your license doesn't know if you're still studying ;)
Licenses bought with the educational discount are the same as regular priced licenses.
They work the same, and there is no limitation on them compared to the regular priced licenses.
You keep them forever.
The only difference is that they are 50% cheaper.
