Address column uniquely via OSC
tlled
Post by tlled »
Hi All,
I am looking for a way to address columns uniquely via OSC. So each column will have a unique ID that is used to address it, and even when I insert or remove columns the unique ID remains the same and the OSC column triggers programmed in other software do not need to be updated or changed.
Any suggestions?
Kind Regards, Tom
Re: Address column uniquely via OSC
You can trigger columns by id via the Rest-API https://resolume.com/support/en/restapi
