AJA KONA X Capture
JanneFIN
AJA KONA X Capture
Post by JanneFIN »
Greetings.
AJA released their newest capture device Kona X, And promises sub frame latency with "applications that support it". Im asking if Resolume is one of those applications.
Quote from AJA website:
Ultra-low Latency / Streaming DMA
With Streaming DMA (Direct Memory Access), the DMA operation happens directly between the video I/O and the computer’s buffer in applications that support it, completely bypassing the on-card memory. Depending on the software application being used, this enables customers to achieve as low as sub-frame latencies and a much simpler method of dealing with dynamic video.
ALSO Please Add HDR output
fiverecords
Re: AJA KONA X Capture
Post by fiverecords »
Hello, I am also interested in knowing if Resolume is compatible with the Stream DMA of the AJA Kona X, or if it is at the driver level and has nothing to do with Resolume. I'm trying to build a rig with minimal input delay, and I'm very interested in the AJA Kona X.Can someone solve the doubt? Thank you
