WIRE Official Documents ?
pyrodigy
Post by pyrodigy »
Hello
Is there any wire docummentation on the internet ?
which expleains detailed node explanations, input and output parameters.. so on ?
Re: WIRE Official Documents ?
Every node has an example patch which you can open from the nodes panel and try out right away ;)
pyrodigy
Post by pyrodigy »
Zoltán wrote: Tue Oct 17, 2023 16:21 Every node has an example patch which you can open from the nodes panel and try out right away ;)
Hello Zoltan,
Actualy, is there any source like this ?
https://infostyle.jp/wire/unofficial-document.html
A short decription of exactly what each node does or input variables, output variables for each node,... ext
Like Handbook of the Node programming language of resolume wire.
We think trying out the nodes is the fastest way to learn about them, so we prefer the example patches over online texts.
We also have great tutorial videos on our youtube channel about nodes: https://www.youtube.com/@ResolumeVJSoftware/playlists
jjpaq
Post by jjpaq »
Zoltán wrote: Wed Oct 18, 2023 08:07 We think trying out the nodes is the fastest way to learn about them, so we prefer the example patches over online texts.
I created an account just to comment on this post. I've rarely seen a better example of a developer living in a bubble than this single comment.
Example patches are a great supplement, but having to stop what you're doing, open a different file entirely (Wire being unable to have two patches open at once really doesn't help), just to read some scattered Comment nodes...it's a disruption as much as an aid. There's zero reason official documentation can't exist, as the linked site shows.
mowgli
Post by mowgli »
I completely agree that there's a need for better documentation besides the examples. As it has been mentioned, only being able to open one Wire patch at a time really affects the usability of the examples and the overall Wire workflow.
tijnisfijn
Post by tijnisfijn »
Jim 2fourK made a great resource... (thx Jim, very helpfull) It has all the help files as a website, and it also has some snippets of basic wire patches.
https://www.2fourk.com/wireNodeDB
mcaglayan
Post by mcaglayan »
This link is not working.
tijnisfijn
Oh, I am sorry guys. I posted the wrong link! this is the database of all the different notes in Wire that he made but if you check out this link it will give you screenshots of all the different reference manuals.
https://www.2fourk.com/wire-tools/wire-reference-libary
And here he collected some snippets of wire patches, which you can just copy and paste into wire, which saves you quite a bit of time doing repeating functions.
https://www.2fourk.com/wire-tools/Wire-Snippets
hope this helps
