Artnet, various network adapters possible?
Holm
Post by Holm »
sometimes I use Artnet for internal control of Resolume, for example to extend the autopilot function to columns.
In my new project, I need to output artnet via my network card, but then the localhost option no longer works.
Is there a way to use more than one network adapter?
Thanks in advance
Holm
Re: Artnet, various network adapters possible?
Using the wired adapter in Resolume should be no problem. I guess you can also set your Art-net app to the same, and then should be able to send to Resolume.
Holm
Post by Holm »
Thank you Zoltán,
it was precisely the use of a second software that I wanted to avoid.
I want to control Resolume on one Universe (default DMX "localhost", TargetIP 127.0.0.1) with itself, and on a second Universe (output over my network card) I want to control my DMX LED controllers.
Thanks in advance
Holm
That should also work with the network IP, if not, try broadcast.
Holm
Post by Holm »
Thank you, broadcast does it.
