"Global" drops?
r2.lighting
"Global" drops?
Post by r2.lighting »
Hi guys, new to Resolume and loving it!
What's the "correct" approach to create drops that "interrupt" all other output from a composition. There seems to be no "solo on trigger" mode or anything similar.
Is it as simple as putting the clips into the topmost layer and piano trigger then?
Re: "Global" drops?
r2.lighting wrote: Mon Oct 30, 2023 15:08 Is it as simple as putting the clips into the topmost layer and piano trigger then?
Yes, that works for most.
