For an upcoming project we are doing a very long landscape projection piece where people will be quite close.
It will make us of x7 1920 x 1080 projectors with 20% overlap.
This gives an effective resolution of about 13,000 x 1080 for the entire canvas.
All I can figure out how to so is up to 8K (7,680 x 1080).
After searching online it appears as though Resolume can indeed handle a maximum texture of 16,384.
But, what codec do I need? It looks like HVEC . mp4 can only do up to 7,680? Is that right?
Also, can DXV 3 handle sizes that large?
What about even bigger?
Until we get AI upscale on a chip for projectors I can only imagine ironing out this workflow in terms of codec and performance will be of use to many multi-projector projects.
Thank you for any tips, tricks, or insights!
Good Workflow and Tips for 12K, 16K, & Beyond Visual Content for Projection Mapping
Lumenarius
Re: Good Workflow and Tips for 12K, 16K, & Beyond Visual Content for Projection Mapping
DXV can do big sizes.
Arena doesn't have a texture size limit, check what texture sizes your GPU supports, that will be the limit.
