OSC question
- rawdesigns
OSC question
can I send OSC commands from my iphone on cellular network to computer on wifi? or do they need to be on the same network?
Re: OSC question
same lan, wan's won't work
tijnisfijn
- Team Resolume
Re: OSC question
But I think that could be done through the rest API. don't ask me how though cause that's really something I still don't really get.
Re: OSC question
Sure, you can send over the internet if you know your modem's public IP, and set up a proper NAT redirection.
You can do the same with the API.
Keep in mind though, that there is no authentication via OSC or the API, so I'd recommend to set up a VPN instead.
Re: OSC question
Yeah without a VPN (makes your WAN a LAN), you're going to probably have to setup a bit of firewall exceptions on whatever network you will be tied into.
Re: OSC question
I'm more about security, VPN is a lot more pain to set up, than a single port forwarding on your router.
