Audio Clicking/Popping sound when crossfading two wav files on same layer
Intange
Post by Intange »
Im getting a popping/clicking sound when crossfading two wav files. Both 48k/16 bit. Ive attached some of my settings. Ive never had this before.
Here is a link to video w/sound of the above.
https://www.dropbox.com/scl/fi/ikp5tlp8 ... ls8e5&dl=0
Re: Audio Clicking/Popping sound when crossfading two wav files on same layer
How long is the crossfade /transition time in Resolume, is it the 0.5 sec seen in the layers panel for the layer you play the audio clips in too?
Intange
Post by Intange »
Zoltán wrote: Fri Nov 10, 2023 11:18 How long is the crossfade /transition time in Resolume, is it the 0.5 sec seen in the layers panel for the layer you play the audio clips in too?
Ive tried with and without a fade in the clips, It doesnt seem to matter. The layer has a .5 second fade. It doesnt seem like its an audio issue, its like the clip being cued creates this pipping sound. Its not always the same loudness either.
We had a fix for something like this in 7.16.
Could you please send us the Resolume log file via the feedback tab in preferences?
Intange
Post by Intange »
Zoltán wrote: Wed Nov 15, 2023 15:20 We had a fix for something like this in 7.16.
Just sent it, im running 7.18.1
Intange
Post by Intange »
Ive realized there is something bigger going on. I started to hear popping while playing one file alone, no crossfading, just a wav in a loop. I left the system playing all night, the next day it was glitching like crazy. I captured 3 glitches. Ive got zoomed in screenshots of all 3 and a recording of the wav file playing. The glitches have audio cut outs, you can see them in pics.
https://www.dropbox.com/scl/fi/g5ouwolb ... si7el&dl=0
Thanks for the files, clicks for me too sometimes. We'll look into this.
Intange
Post by Intange »
Zoltán wrote: Tue Nov 21, 2023 12:19 Thanks for the files, clicks for me too sometimes. We'll look into this.
Hey Zoltan, Any updates on this or should I back track to 7.16 for now?
Thanks in Advance
