I'm having troublr seting up resolume to work with my dual out nvidia card,whenevr I try to set up one output as fullscreen and one as preview I just get two blank screens. How should you have nvidia dualview set up? I've tried all the diferent mode and none seem to work, I'm useing the latest drivers.
Any help is greatly apericiated.
card is an nvidia 5700 LE
						Nvidia dual out
				Anonymous
It may be a bit tricky with nvidia
it seems that you have in overlay on primary screen in display settings - so the resolume puts output on disp 2 and windows copies the overlay to no 1. So you get 2 outputs and no interface.
You need to change overlay (aka fullscreen video) settings in windows from primary to secondary output.
hope it helps
hope it helps
Re: Nvidia dual out - Interface appears but no Fullscreen output
I also have an Nvidia Dual Out card configured with Dual View to span monitor 1 & 2 but a different issue:
When I start Resolume 2.41the interface appears on monitor 2 but I am unable to configure fullscreen on monitor 1 (or the reverse) from within Resolume.
In Resolume under screen setup if I choose
Preview for monitor 1 and Fullscreen for monitor 2
and select apply, there is no change - I only have the interface on monitor 2.
I tried reinstalling Resolume and the Nvidia drivers with no luck.
