Wire : sync oscillator freq to BPM
weppingpresent
Post by weppingpresent »
Hello !
I am new to Wire, I am trying to match the BPM to the frequency of an oscillator. I saw the BPM to frequency node which is very handy, but where do I get the BPM from ? I want it to be an input from Resolume for when I import the patch into it.
I tried several thing with the Transport Beat node but didn't get anywhere ..
A simple BPM node that gets the BPM from Resolume would be great !
Also, another problem after what will be to make sure the path is on the same beat position than Resolume ..
Any idea ?
tijnisfijn
Re: Wire : sync oscillator freq to BPM
Post by tijnisfijn »
check out this patch. hope it helps you out
--begin-wire-patch--
1110.3ocsW01aihCD9uRk+L9DFLFb+VdiS6W16jtJceXU0JC3j36.bVvzt8px+8aLPHjMIjta2sRowPlYXlm4YdgWQo5xRYpQoKqQ2+oWQqqzEvAeGTxtBziNHiFtj5fTk6ZLtnG26LHTfCR2XfaOHGyAUIxTM0mHWnCZWt3kAoh5s1YBIZpkSKE+rGI3DqqjeoQVl9xIhFclnfx0x7tn8DQoGD0crrCQ7i8m+ipLYE7av0ERi.c+qHQiYqFtGB4fREF4Fc0Kn6KaxycPYxc45WJjklGDUajFq7IUhxzscxWJJjvo+VUIgqdRVUa8KPnBw+XsIfHEpR6IB0BNFqht62asbcZkZWabzZpLUsEg+XmEganxfGqZsx5uHuTYJKijgYj.WLkQX3DQ.GmRxnIQBtjQS.cxUoxxZYrJu2H823nUKDp7tS5J0FUoH+cGYQCQlmMx9RiHWY.Hz2KJvxlj057FSu5akpMagmFwMx0A8rJy.5Q3dtfl0hmj+r8Fy1lhjxgftop+vSxxrtrNHTo7qlOpyjeHy5Xv0v4Zq48aIHFSkJowzdKP5DcSYV8IAi+3XAnyeEcOGp+rfPHCTIMWT2pgBdBnvPFOziEfYr4DLcgWDdVvLNlDyntdrkvOOebX51ZAc5+B59DPKzVlpNu08WC+wDtts2pr1HJM8t4VUFvf535832C.jVuSWYt6CkqsVY.c97SpZUhk0XpZjf1zyhbz5b8y1uMuryZr1KAuTj2XurVsAHSVzrqnCmof5l5ttRCJoJgBLfQOnG4nBchLHZ6WGsO73DFz9Kh+W.98ChZwepK853+R1LnXxyOFy4wQXlaT7rfUt9q3giwex2O9enyyIvE3+CwSaSfgTzAvbLRbIf7Xpb9th6L56hG5aNUxL37jI3mJLTnJFmcRz57it3ZQdsrM8XCqT4MyiMkpc5bQ0Mr3atDJhx5pgBhtdNLlGDiojkQ3n3ET7xX2kKBXqHtAj2aNTTrC5j0jIudZzZ1iyttd1927B.I0qWW20b6ZjBn40VQsD+VjDZrJM3V4GW1.s0OIyXmjcJYarhixZNiIEiS6GYc+k34IIZryIZuQ1yEIE1Z3ugSPfDaGoviecRwpYdLLMbICyiBlgmSWLa0BeBcd76tvte4nIR0Amh1WBGWnpRykSBkgu6QODp+DidhH1QOjX77HNCGub17n4yYqV5w9EO54Os6QNUjG8ykDcogC8MVHSMbllIANjj5h4g7DbhGiDJXIBIULFg79QGNbyZV6ptlXaKy2lnOT07c1H3fRidRWtt+A8lM2fuxeOKL7FGvLr5+M1Uncpic4ue3MJh7Nizvb6mFwoSUVw4X5L9Bbj2r4XNkGRXt99Tp6u9MJ52XfLsLGe+oqMltMi9MDkS.dmCP4vZKmSY9c3UolfvzM+R2Tkdn2Vix5Pof1UsuWF.4ts.N7++SaeIOxod+mP1l4QvGejk+YWZ0tqicLzi62++v7Ql76
--end-wire-patch--
weppingpresent
thank you, but I don't know how to make this text into a wire patch, can you help ?
Copy the text and then in Wire just paste it in the center area.
