Lack of general keyboard shorcuts, am I missing something?
JBroadway
Post by JBroadway »
Hello everyone, I just bought Resolume Arena and I'm having a ton of fun messing around with it!
I noticed there appears to be a lack of general keyboard shortcuts and I'm not sure if I'm just missing them due to ignorance...
Things like:
F2 - To rename
DELETE - To delete clip (I've just been using CTRL + X as a work around)
Shortcuts for deleting layers/groups
Page Up/Down - For cycling through tabs
Basically I'm just looking for a way to map the right click menu to to key bindings so things like Insert Above, Insert Below, Duplicate, Rename, Clear Clips, Remove etc... Can be called without clicking.
Is there something that I'm missing that already provides this functionality? If these things aren't possible, I may just write an AutoHotkey script.
Any help is much appreciated.
_Ineffable_
Re: Lack of general keyboard shorcuts, am I missing something?
Post by _Ineffable_ »
I fully agree on this...
I hate having to go into the menu to rename - only to accidentally click on remove...
Yeah don't worry! I put it on autopilot!
subpixel
Previous and next deck shortcuts
Post by subpixel »
You can assign shortcuts for:
Composition Selectnextdek
Composition Selectprevdeck
The controls are at the right end of the AB crossfader widget, in the transition controls column, visible only when you enable "Show Layer Transition Controls" in the View menu.
_Ineffable_ wrote: Sun Sep 15, 2024 12:43 I hate having to go into the menu to rename - only to accidentally click on remove...
There is a number of things selected at a time, at least once clip, layer, column, or group or group column or deck.
Which one should the rename shortcut work on?
Ciandoeslights
Post by Ciandoeslights »
Everything. That's the easiest option right? If you fuck up you can just undo, and then select the one thing you wanted and rename that.
Renaming in resolume is SOOOO arduous, clunky, but for a set it's very important.
Also please sort out your text boxes. In arena, some select all text upon selection, some set the cursor on the last letter, some start the from from the first letter!?!?(Wtf)
If you're trying to organise a show, between having to right click and scroll through the menu and then upon clicking rename having to remember which type of text box it is, there no room for muscle memory or efficiency. It's just clunk
gforce_vj
Post by gforce_vj »
Im hoping we can get native support with STREAM DECK and u can build custom banks of hot key short cuts - agreed will take time to set up but once done you golden, best of all u can label them of give them icons - there is limited control thru Bitfocus companion but maybe worth a look into - it can also be used for all your other DAW shortcuts
JBroadway wrote: Fri Dec 01, 2023 21:07 Hello everyone, I just bought Resolume Arena and I'm having a ton of fun messing around with it!
Things like:
F2 - To rename
flxfjs
Post by flxfjs »
Zoltán wrote: Mon Sep 16, 2024 11:16 There is a number of things selected at a time, at least once clip, layer, column, or group or group column or deck.
Only on the last selected item: you click on an element, press Ctrl + R, and that’s it: you just type the new name and hit Enter.
It shouldn’t matter whether the item is a clip, a layer, an effect, or a source.
This works perfectly in Ableton, for example.
