Hi All.
In Resolume i would like to have Composition settings that stay the same for that projects.
Now if i change the size of the composition for a venue and open an other project, the Composition
stays the same? am i doing something wrong?
Let me know, Michel
different project same composition?
OnlineZoltán
- Team Resolume
Re: different project same composition?
In Resolume, the "projects" are called compositions.
If you load another composition, the compositions change. Compositions can load shortcut presets, but won't change the advanced output settings.
Yes and that is what i would like, that advanced output settings will change with changing the Composition.
Is it possible or is there an other way?
Thanks for the reply.
OnlineZoltán
- Team Resolume
Is your output setup changing at the venue, or is this about different venues?
Different venues
Can´t you save different advanced output settings and then load them, according to the venue? But maybe I didn´t understand your question correctly :/
You can have the same composition for different venues, which I usually associate it in advanced output, maybe the same clips for the same event but in different spaces, just an advice, if the output changes a lot between the venues and you need to scale or reposition some clips or logos, save as the composition for that venue.
But to answer your question the advanced output doesn’t change with the composition.
If you change the size of the composition it changes thae canvas but the clips remaing the same, it doesn’t auto scale.
