Cube Tiles
afreemind
Cube Tiles
Post by afreemind »
I want to map my composition as an effect onto a cube - I use the Cube Tiles effect for this. Unfortunately, the effect does not allow a single surface per side but only 4 surfaces (see also post from 2009: viewtopic.php?t=12606). Is there a way to achieve this in the meantime?
On the screenshot you can see that the area is always played 4x with the composition, but I want the composition to cover the entire cube area.
