Avenue 7.18 goes to black screen on Mac
Timeop
Post by Timeop »
All was working well until I started the app. It goes directly to a total black screen on MacBook Pro 2023. I replaced the prefs in the Mac Library, any other place to trash a pref that might have started this? I also reinstalled Avenue. Thanks.
tijnisfijn
Re: Avenue 7.18 goes to black screen on Mac
Post by tijnisfijn »
Maybe I am asking you stuff that you already tried, but would it be possible that arena starts up and the output is in full screen mode on your mac monitor? try shift-command-d this should disable output. When you say your screen turns black does that mean that everything gets stuck as well? Or do things like command tap and show desktop gesture still work? Can you still get to the Finder or does your dock still come up? Or is it really stuck? What do you have to do to get back to normal?
Timeop
Post by Timeop »
Wow...it looks like that fixed it...thanks so much...would never have thought about it. you saved my weekend.
tijnisfijn
No worries you're welcome. Happy Christmas.
