Bypass or Mute buttons on video and audio layers in composition and layers
drxian
Post by drxian »
these would be very useful to have please..
need a simple way to mute audio whith out destroying any audio volume animation or effects..
ditto for comp and layers video . simple byapss would be very useful..
mowgli
Re: Bypass or Mute buttons on video and audio layers in composition and layers
Post by mowgli »
Can you explain the context in which this would be very useful?
If I understand right you want sound reaction but no sound...
You can achieve that by turning down the volume of your computer.
subpixel
Post by subpixel »
I would say that audio mute (/bypass) is as useful in Resolume as it would be in any DAW, multitrack audio player, etc.
I have a gripe about the B(ypass) switch applying to both audio and video at the same time. I use Layer-to-Slice routing in Advanced Output for non-trivial projection mapping, and that means I often want to exclude layers and/or groups from the layer blending pipeline, but I may still want the audio from a "Bypassed" layer. It has messed me up a few times and I have to live with a bad compromise.
