Juicebar "counter" plugin
EBMCreative
Post by EBMCreative »
I have found a bug and I want to request a feature.
The bug I found is when you have a counter set for after midnight and are running from before midnight thru the morning.
The bug is that at midnight when the date changes in the computer the plug-in does not get a date change information internal. So if you have a countdown set for 2am it goes from 2 hours to 26 hours countdown.
I also have a request for for a feature. My feature request is to have it be able to do day or days countdown. So you can set a counter a week away and it will say 7days or 6 or 1day.
With that request. It would be nice to have 3-4weeks of selectable days.
Thank you.
Re: Juicebar "counter" plugin
You'll need to get in touch with the author of that plugin. Should have the name in Juicebar.
EBMCreative
Yes I posted a comment but it hasn't been approved yet.
