I have a project where I want to sample an image, in perspective, then corner-pin those areas onto a square surface.
However, the stretch is pinching across odd areas instead of an even stretch. I was trying to pick 4 points of the input, then square those up on the outputs.. but that's not working.
Is there a way to do this? My current input/output screens are attached.
Polygon stretching points not working as expected.
Re: Polygon stretching points not working as expecte
Ianmcdan, are you using the large square edit points on the advanced output ?
The small points dont do perspective correction.
The larger square edit points don't exist with a polygon slice sadly.zaniz wrote: Wed Jan 10, 2024 20:59 Ianmcdan, are you using the large square edit points on the advanced output ?
