9 new effects
MarkyMark
9 new effects
Post by MarkyMark »
Hey there friends, buddies and champions!
We're here with a little something-something for all you effect-lovers out there.
We've taken 7 effects from Wire examples and compiled them for Arena and Avenue.
This means you can install these effects without owning Wire.
Downloads can be found at the bottom of this post.
Because the love is strong today, there are two brand new effects in here as well that were requested on the Slack Channel. Note that these effects will eventually make it to JuiceBar (for free).
Requirements & Installation
  • Requires Resolume 7.18.2 or higher.
  • Download the effects and execute the files one at a time.
  • Arena/Avenue will open up asking you if you would like to install the effect.
  • Now you'll find the effect in the effect panel.
Smooth Transform
The Smooth Transform effect functions like the regular transform, except there is a transition between the values. This allows for buttery smooth scaling and translation. The best thing is that you can set the amount of smoothing.
Screen Shake
Let's go boom-boom on the beat and shake your entire output.
This effect will allow you to temporarily distort the heck out of your content.
That trigger button really loves some BPM-syncing!
FeedbackPro
This effect is your one-stop-shop for all feedback related wizardry.
After luma-keying the footage you can move, scale and hue-shift the feedback for some seriously trippy results.
SlitScanner
The Slit Scanner is another feedback-based effect that allows you to sample a single slit of your content and repeat that infinitely towards the end of the screen. It's like putting your hand under a scanner and moving it while the machine scans.
Shifty
This effect is directly taken from the Wire tutorial on creating distortion.
At first glance this effect lets you distort your content on the horizontal or vertical axis, but as soon as you apply some smoothing and rotation a whole world of distortion effects will open for you.
Space Warper
We are not 100% sure Hawkings would approve of this effect as it WILL bend space and time! use at your own discretion.
Reducto
This effect allows you to reduce the color and image quality to get some lo-fi looks.
VHSifyer
This is a customized version of the VHS example in Wire.
This effect gives footage a VHS look by adding scanlines, slight distortion and some chromatic aberration. Works nicely with the Vignette effect too!
Total Visual Annihilation
This effect will wreak absolute havoc on your content.
TVA is here to murder your pixels, eat your colors, crush your animations and spit out filthy grimey glitches until your eyes bleed.
And that's it for now!
Stay tuned, as I'll be porting over some Wire sources soon.
Total Visual Annihilation.cwired
(55.6 KiB) Downloaded 50843 times
Smooth Transform.cwired
(27.63 KiB) Downloaded 48372 times
VHSifyer.cwired
(115.91 KiB) Downloaded 49598 times
Reducto.cwired
(9.58 KiB) Downloaded 46737 times
Space Warper.cwired
(578.87 KiB) Downloaded 50668 times
Slit Scanner.cwired
(79.32 KiB) Downloaded 48664 times
FeedbackPro.cwired
(1.54 MiB) Downloaded 48842 times
Screen Shake.cwired
(132.55 KiB) Downloaded 49234 times
Shifty.cwired
(520.26 KiB) Downloaded 49828 times
tijnisfijn
Re: 9 new effects
Post by tijnisfijn »
And it's not even Christmas...... :D thx
zaniz
Re: 9 new effects
Post by zaniz »
MANY THANKS !!!
Larius
Re: 9 new effects
Post by Larius »
:D super nice
mowgli
Re: 9 new effects
Post by mowgli »
This is great!
I made a test-drive video for Feedback Pro:
GroovinDJ
Re: 9 new effects
Post by GroovinDJ »
Thanks for making the video @mowgli
I didn't know about these until seeing your video.
mowgli
Re: 9 new effects
Post by mowgli »
GroovinDJ wrote: Thu Feb 01, 2024 19:05 Thanks for making the video @mowgli
A pleasure!
MarkyMark
Re: 9 new effects
Post by MarkyMark »
Thank you for the video Mowgli!
mowgli
Re: 9 new effects
Post by mowgli »
MarkyMark wrote: Fri Feb 02, 2024 12:03 Thank you for the video Mowgli!
A complete pleasure!
I had to after getting genuinely excited about the interaction between BPM Audio Shapes and Feedback Pro. So much so that I've made a whole music video using just them too. I'll be posting it here soon.
mowgli
Re: 9 new effects
Post by mowgli »
Here it is, a music video I made for one of my improvised modular tracks.
The whole thing was made with a single clip using only bPM Audio Shapes and Feedback Pro:
