Disabling Arena pop up settings
moha20106
Post by moha20106 »
Hi all,
I found the solution for the flickering problem that annoying me during shows
You should choose Ignore the Nvidia settings after installing or updating the gpu driver
The solution proposed by Mr. 3s-technics, who mentioned it in this thread (page 7)
viewtopic.php?p=92934#p92934
Now i have to disable the pop up that appears at startup
When i choose Ignore, This pop up always appears at every startup
How to disable it please ?
Note: I tested it yesterday while connecting 3 Hdmi outputs, No flickering happened anymore
Re: Disabling Arena pop up settings
What nVidia settings have you changed that Resolume is asking to restore? THAT would be something to look into.
moha20106
Post by moha20106 »
Arvol wrote: Sat Jan 27, 2024 15:41 What nVidia settings have you changed that Resolume is asking to restore? THAT would be something to look into.
The pop up small window that appears after updating the gpu driver
Asking you to restore Nvidia settings or ignore
It's only appears when you start up the Area
I know the popup, I'm just curious if there was any changes that was made in the nVidia control panel that wasn't set by default (was anything changed by users?)
moha20106
Post by moha20106 »
Arvol wrote: Sun Jan 28, 2024 15:04 I know the popup, I'm just curious if there was any changes that was made in the nVidia control panel that wasn't set by default (was anything changed by users?)
No changes, Just the disabling the Nvidia settings
We have a ticket for this.
