blackmagic playback problems
AdamDGK
Post by AdamDGK »
I would like to get more output from the computer. I use a blackmagic 8k card for this. Unfortunately, the image is not as smooth as with GPU. I tried a low resolution of 1080 60p to eliminate the bandwidth problem. the card is connected to pcie 8x so there shouldn't be any problems. Capture works super smoothly. I also tested sending in vmix and 2160 60p works without any problems. where is the problem? someone use 8k blackmagic cards?
Re: blackmagic playback problems
Have you tried setting 4-10ms of delay on the output from those cards in advanced output settings?
AdamDGK
Post by AdamDGK »
Yes. I tried with different values. on two different servers
I know a few years back with BMD cards it was like driver roulette. After about 7-12 revision installs I finally got a version to work. Might be outdated or too new of drivers?
dcaiman
Post by dcaiman »
What computer configuration do you have?
CPU model, motherboard, graphics model…
What cards do you have installed in addition to the graphics card and the 8k Blackmagic?
AdamDGK
Post by AdamDGK »
I only had blackmagic for testing. I was thinking about buying it and it would be great to have an in/out card for this price. with vmix it works great, so I think it's not a card problem but a resolution problem. pc is ryzen 7900x, MSI MEG X670E board, 64 gb ram, 4080 rtx. card installed in pcie x8. all pcie lines on this board are connected to the processor.
Try adding a few ms delay to the Screen in the advanced output.
AdamDGK
Post by AdamDGK »
of course I tried but it didn't help
Composition, footage and the BMD output all set to the same frame rates?
How does the playback look on the output limiting the composition fps and the output to 30?
