Snapshot improvements
mowgli
Post by mowgli »
It would be good to have the option not to have snapshots automatically load into the composition.
At present, this is quite disruptive, especially because the interface focus automatically moves to the imported snapshot.
It would also be good to be able to select a folder for the snapshots to be saved.
All these functionalities could be easily incorporated into the Record tab.
tijnisfijn
Re: Snapshot improvements
Post by tijnisfijn »
+ 1.....
Christoph
Post by Christoph »
Output folder can be set in the recording prefs:
Screenshot 2024-01-30 112622.png (31.14 KiB) Viewed 11131 times
Automatic scrolling can be disabled in the preferences:
Screenshot 2024-01-30 113031.png (11.15 KiB) Viewed 11131 times
Made a ticket for the snapshot auto-adding to the comp being optional.
mowgli
Post by mowgli »
That's great, thanks.
Regarding scrolling into view, I do want that enabled for general use, the problem is the automatic snapshot load.
Regarding the folder, I constantly want to send snapshots to different folders, doing so from preferences is not practical. Both snapshot and Record folders would be better assigned from the record tab.
Scratchpole
Post by Scratchpole »
+1 from me
I actually forgot it happens and thought I was seeing a ghost :)
