sorry, if this has been asked/answered before:
i am working on a mac. The second monitor, which will be the live stage, has a green dot on the upper right corner. I found out, that this is a security feature from apple to indicate that a camera is in use. well, yes = i am importing a live video feed into resolume. i tried to disable camera input into resolume, but then the live feed is no longer available.
I dont want the green dot to be shown in the live presentation. Do you know how to get rid of the green dot on second monitor/screen? thank you for your help.
green dot upper right corner mac os
Re: green dot upper right corner mac os
camera is in use https://www.google.com/search?q=green+d ... +mac+os&oq
you mean: No, there is basically no possibility to get rid of.
what do you resolume people all do? accept and proceed? not use a live feed as input?
It's an OS setting. I don't use mac's so I can't help you there. But it's something you can turn off in privacy or something if I recall. It's in your system settings not in Resolume.
tijnisfijn
- Team Resolume
there are always solutions....
try this https://github.com/cormiertyshawn895/Re ... torUtility or this https://cdm.link/2023/10/fix-the-orange-dot/ one of those should to do the trick....
thanks a lot, i am looking into the app. that was helpful
See this Link it's helpfull
https://support.apple.com/en-in/118449
