what is the FPS limit when sending Artnet?
mdethmers
Post by mdethmers »
Hey all, I tried to find this but have not been able to find anything on the internet or posted to the forum yet. I was wondering what the max FPS is that you can send over Artnet? I am planning on controlling LEDstrips with a controller that should support over 80+FPS for 3 universes, so you are not running into the Hardware limit of the pixels, but have not found a concrete answer on the FPS that resolume pushes to artnet.
I know that DMX artnet is limited to around ~40FPS, but as there is no DMX (max485) in play here, it is possible to go higher right?
Re: what is the FPS limit when sending Artnet?
The max you can do in Resolume is 40 FPS.
