Smart Gaussian
Sjan Top
Smart Gaussian
Post by Sjan Top »
Hey there,
i'm running Resolume on a old potato, so i like optimised effects.
So i thought up a way to render Gaussian blur with higher frame rates, just down sample the shit out of it :D .
I add two patches, the first one is simple (use and forget about it), but because texture the resize is calculated in attribute space, no animation/preview of the strength. The higher the blur the better the framerate
The second need a bit more input, you can select the render resolution of the Gaussian blur. With this one you always know the frame drop. And you can animate the strength, because its calculated in signal space.
Have fun!
* i don't know enough about the core of wire and resolume, but it would be really nice if idea would be build-in. Rendering at 1/8 saves the world of resources.
Smart Gaussian.wire
(233.83 KiB) Downloaded 554 times
Smart Gaussian (anime).wire
(233.26 KiB) Downloaded 553 times
tijnisfijn
Re: Smart Gaussian
Post by tijnisfijn »
thx & cool.... really smart thinking.... "The higher the blur the better the framerate" . that's brilliant.... ;)
Sjan Top
Re: Smart Gaussian
Post by Sjan Top »
Thx!
i think its a technic they use with mip-map textures. So at first i just tried to downsample in Wire with the resize node. But the linear interpolation of the upsampling gives ugly results, but a bit of gaussian blur fixes that :).
magneson
Re: Smart Gaussian
Post by magneson »
It is also the base of the original bloom effect. Downsample 8x/4x/2x/, blur and additive blend and it glows :D
Sjan Top
Re: Smart Gaussian
Post by Sjan Top »
I know :), just finished a update to the patch, Bloom and Highpass are both based on gassian, so i build them in to the patch. And added displacement for 'bokeh' like effect.
The highpass has a mask, so you can apply it to the grey pixels, this reduces clipping.
The same toggle reverse the mask of the bloom.
All effect that are not used get disabled, by 0 value or toggles
Smart Gaussian 1.1.wire
(294.5 KiB) Downloaded 589 times
