resolume, madmapper, and DVS
Anexus
Post by Anexus »
Hi, I need to share audio coming from DVS to Resolume and Madmapper, both running in the same PC (Windows).
Im unable to do it.
When I select the dante virtual soundcard in one of these programs, im not able to use it with the other.
I have the same problem if I use my roland soundcard as input.
Any idea on how to do it?
I just need a shared fft input for both softwares. Midi clock is ok, as ableton link is working properly in both softwares at a time.
I´m using resolume for video and pixels, and madmapper for laser control.
tijnisfijn
Re: resolume, madmapper, and DVS
Post by tijnisfijn »
I use blackhole but thats mac only... i thing this does the same for pc... hope that helps you out...
https://www.nerds.de/en/loopbeaudio.html
Anexus
Post by Anexus »
Thank you, I will give it a try. I would prefer keeping it as simple as possible, but it seems that I need to use another piece of software to make it work...
Try setting DVS to WDM mode instead of ASIO
