Has anyone used Resolume on an Imac via the Bootcamp emulator?
Is there a better way of running Resolume on a Imac?
Am I an idiot for asking?
Resolume on Mac via Bootcamp
here is a picture of me operating resolume on a 1.83Mhz macBook pro and it runs very smooth! 3 layers 320x240 @ 60/70 fps.
we,ll hopefully do some more testing later this week to see if the dual monitor works ok.
[Edited on 24-4-2006 by bart]
- Attachments
- Resolume_macbook_600.jpg (69.01 KiB) Viewed 21704 times
boganrobotlightning
stanleystark
Resolume runs perfect on the macbook pro!
The only problem with the macbook is that the s-video out does not really work. Dual monitor on the DVI/VGA port does work though.
more info in this thread on vjforums:
http://www.vjforums.com/showthread.php?t=16055
stanleystark
I'm going to put my new 17" through its tests tonight. And yes there is no current TV out option so a scan converter is the only way to go for now.
Interestingly when running a 20" Cinema display of my MacBook in windows I do get glitches on the (primary) laptop screen when just working in windows so I would say that the video drivers (as alot of other drivers in XP) need some serious bugs fixing.
For those of us with a MacBook I've been following/posting on http://forum.onmac.net/forumdisplay.php?f=29 forums and fixes to some of the current bugs in parts of BootCamp have been fixed, especially sleeping & sound.
Back to Resolume, ran some tests last night, crashed once randomly within a couple of minutes, but then restarted Resolume and seemed to then run fine for 30mins.
Had 3x 640x480 clips, 3x Main effects and no noticable lag - messing with FX knobs via midi was very responsive. Expect a post on the weekend on my live experiences - of course we'll be running a second machine as backup/support.
[Edited on 31-5-2006 by lotech]
