How to create Pixellate Effect in Resolume avenue or Arena?
Lumenarius
Post by Lumenarius »
I am looking to do the classic pixellate effect in Resolume Avenue or Arene.
I can't seem to find this effect. Given it is a timeless effect there must be a way to do it?
You know, the square blocks that make a visual look low resolution?
What is it called in Avenue?
tijnisfijn
Re: How to create Pixellate Effect in Resolume avenue or Arena?
Post by tijnisfijn »
Under the effecttap there are a low res effect and a Pixelizer fx. One of those should do what you want...
Lumenarius
Thanks for the heads up I will check that out. I figured it was under an alternative name.
Also, for those in the future I highly recommend the "Mosaic" effect from the JuiceBar project.
This was also a different name than expected but worked exactly as what we were looking for.
https://get-juicebar.com/detail/mosaic
Thank you for the tips!
