I'm looking to get a laptop with 2 4k outputs, but I really need them to be frame synced... Does Nvidia Mosaic take care of this? I'm looking at either an RTX 4090 or RTX 5000 (laptop versions), does Mosaic work with those GPUs?
If not Mosaic, is there another option that is easily available for laptops?
Frame Sync with Laptop GPU
Re: Frame Sync with Laptop GPU
Only Quadro cards support this
Luisgoinsane
Also geforce via surround
Has surround fixed issues with tearing? Last time I tried it was in 2018 and it was 100% unusable for larger setups. Tearing all over the place.
A Quadro and sync 2 card is a surefire way to get the results you're looking for.
Luisgoinsane
Surround and mosaic has worked fine for me I also think the cables and nova processors affect in many ways. I havent tried the quadro sync. Have you?
Yeah Quadro's with Sync work every time.
