Problems with framerate in Mac after update.
Starlordz
Post by Starlordz »
Hello y'all!
Hope you’re doing alright :D!
I’m experiencing some fps troubles with my MacBook Pro M2 since the two latest updates. Since I updated the the latest version of resolume I have my fps oscillating from 28.54 to 29.84 (I have my composition capped to 30 frames for LTC reasons) this haven’t passed in the past with this laptop and when I set my composition to 30 frames.
I’m worried right now because in the previous update if I set the composition to auto my framerate went to 120fps and now it’s set in 60 frames if I set the composition to auto. This situation is worrying me because I’m touring right now and I don’t have time to change my rig right now.
I hope that you can provide me some info regarding this issue and if should be worried if my laptop will crash during a show (I certainly cannot afford this right now D:)
Kind regards
Re: Problems with framerate in Mac after update.
There have been some performance issues with the latest Sonoma update,
If you want to try an older Resolume release, you can get those from the bottom of the download page.
Make sure to backup the Documents/Resolume Arena folder before downgrading.
