Advanced Output weirdness mac m1
Grimm90
Post by Grimm90 »
Hi , ive seen this issue a few times but only had a good chance to record it yesterday on my phone.
Its hard to explain , i guess the video shows it well , something is completly weird in the advanced output screen. i cant resize my canvas , the texture is like scrolling behind the view canvas box.
No idea what causes it, i think order of starting up software and or connecting / disconnecting projector. ill look for a pattern that creates it.
Restarting resolume fixes it and then it stays stable so no biggie i guess but probably word knowing at resolume HQ ...
Grimm90
Re: Advanced Output weirdness mac m1
Post by Grimm90 »
Grimm90
Post by Grimm90 »
Sjee this forum is really kinda dead nowadays :/
If you close the advanced output, then resize the main window, and go back to the advanced output, does it work fine then?
If so, it could be related to the external display scaling, when you connect the display with Resolume already running.
Grimm90
Post by Grimm90 »
Im gonna try that next time it pop ups . Restarting Resolume fixed it last time.
I dont think i got any scaling settings on i tend to check for these things ,but i will have a look. Thanks for the reply !
if you're on a macbook, I'd say you're very likely not running the built in display at the native resolution, so there will be scaling going on, but on your external display, likely will not be.
Grimm90
Post by Grimm90 »
just checked and you are right it was scaled , native is 3546 x 2234 pixels and i was using it way lower.
Damm now i want to use it full res but the text gets too small :D
