Find brightest parts of an image
col-neck
Post by col-neck »
I am pretty new to wire and I try to create an effect that draws many lines between the brightest parts/blobs of an incoming texture.
I thought I'd take the Line Trails from the examples as a starting point but I even struggle to find a way how to convert the pixel values (bright pixel) from a texture to data, that I could use as the inputs for the line segments..
Any help is appreciated!
Cheers,
Jonas
Christoph
Re: Find brightest parts of an image
Post by Christoph »
This is not possible in the recent version of Wire, but we're working on it and it might become possible with the next update...
tijnisfijn
Post by tijnisfijn »
I disagree.... ;) you can definitely do something like this.
Start out this I hope this helps.
--begin-wire-patch--
1119.3ocyW0zaiaCD8+BOKEPJQ8UtI6DWrG51KEnGVDrfVh1hMTjdknbhaf+u2gRx1xeDYmcSApCP.E0LC4Lu2ibzanLsRwyLBspFc+2dCsnRWBCvNHciYUiA8jCxngYHNHgpchsN6MidlY9WxLxNyvCsqjU+LX1S8d7GU47J3MvykbCCc+aHVioPCygPNnLlguTWsAcupQJcP47UR8lRtx7mrpkbi094ULUVQm8JVIGF8WhJN7zZdUMjiViJY+sMlQvxHT1QjXGzJlw5Hd6VajqypDqLs1aCUtndkjs4qcQDlPjCKqXgvteQbJKHCOm3RnXOWJgL2MluXgKMeQXhOMNfsfB9HEYbUMelP1Gj9IND0RlP1MRWIVJTL4ublkrOy7rY1OZXRgAJg9dwAgNnJdsV1X5cufKVV.qFAGCv+KhbSgMDdXvyZ1Z9m8twTzTNWsOoap5Grlqx6PcvHE+UyW047ujitO.dDFVaiNtkeXLUh4MltolKL.ovtoeCY1rxtqDJfz.nDDTlrgaA3V1UgN+pVAqz0r4P8ykMuc3PWVH0Li2AO9lsV5XqtOcruevkphKYFw5wWJGhcQ5d86GYhEGlqaT40CY.wdCvenp+JfXDPwBLGunXvkLIqt0CATGQQQgIQdgAtyl9Hn.dbxitwSiItIISChhC7nodzgbCRaDzYOC9tFzRZq7VKaw7EvuPFF2Nkp1vTlNvcyp9krOWlq0xCIxBlrlusOLjSqLziqLN8UmVi8FyXri8uViyElBqd+XiGBRfQEhb3nAvwc6289cNfeYL8xjJmCj6872dzsmo9zdk3uUwxEv4SnAJruuVTKlaO4wT0XqSjykOP97xwo2KGxNTsXIbfjUQJTYxlb92g2eT83X.oec1YbypUiX7Nzq8d.2bAbpdc2MRiQc2Y+Ij79pxtMtAN.ooh6ka26krW+.g2Z83Aumvrs8LtORjAqusHeq5SJM355yGlkF4RmkF3lf8RboXbbXPX.1y2en9z6mPe1co+fzYeYeeNYu2tqpdi5SnJMp37tXb6Oh8f0Du3jPmacNH9GIW6Y6CHTWfMN.2NCvGvVNilcpl4TYwSCtE0T.I8XJW+yUteXYfnE3x30eN2MDgSZ4djHx6y8lNINzklFNyMMcRpKFmLkNMdxjfojeUt2sd2PAC50UdsaZuclrPAaayUW219bud7NhOd.gNgTtKIb1k0GHO+tccFi5P+46Y5FYL+uuknKRoI93y3z99cmmFQeeJMFmBTZRnu6jGRSc8d7gojYgdoOjdT6N9+G2tys2sSS4QWMcRGLV3iqX.iw0T.E2BsL+p6fJ8KiERb2GOTtBBZ2GCNNlBG+k8rhWWOJRdmWR6u.OeRnWLE9BN+6ncGxmD3GFQg4osM.egD4zF2tK3cZca39dXntPY5Sr8tCRsg8zIxGQZ2KFZp5DnviMBaBmAdW09kz.iF2xmg++OZKNXQ6Ztr6a+sos8XXKOz1J.E9t7s+q9b9Bp
--end-wire-patch--
How would you draw lines between these points using 7.19.2?
Code: Select all
1801.3oc6clzaaiCE.9uRfNKUPQs2adsXNLcFLSAlCEFCnknsYqjnqDkSxDj+6yiRxRxQdIMsWJvyo8YY5Ot7VHYeLEfOYDKyy4wJgLuz38e9IiMExL3AaSi8LkhWjarxzPIghbf2KX4kajEYLcELV8rYWEHlFxJ09JEYXE1xkYbUwimf5LF0yzHiWt6DLuwX9lFhbnjS3BMMJ4fZjT1wE0xQOAL5XC1wE.krYSI+zFLXDGzuYrxuBTqZa4+nHgW.eyJ8.WwLd+SFrJ0NITlggoQLSw2JA8984UoolFI78oxGy34pOwJ1B8GvuFLlw6Z3yYYb3o+QTvgOcfWTpsu.TF6K51DFRYhb8STRsmQWQxyOqa4x3Bw9Z+QcSkHJ2mxd7iMsHTfHA5VwFgd7Z3ZuNxMLZs0ZdL0x0Ov0hEF3Y4v8Hdwd1DeOGnNohXddIeoHssQZKnuUyXhzlmjEhshbV5OaM6aUrTgBLgNzPOvCTvKkoUp1puiK1tC5MaRHTu6EIJnd1QTBTyR1A9O6QiZWU157Nktpn8gC77jFuN.kyeP8QYB+2RfwBLEJGdtT27j5.DkpPrtR0TjHuTACrlOndbudbIxgvFvOAMKKsBJw94Wp2WhzMTOJWKqzyCFXe7BGXcfoTO.uaZ7nVqfvzTVYyfAFvFAA9QATeOqEdybshntSsltvmZszc4TmkzkNylDMzp0zBx3uB08.DkI0A9xzZqwF3kOiPpKpVSU0cTAKQTMTk2jJYpd0f7NBIp4ELbbCodgPuTcXXUVKeflzWEsy6g5krrWU69pWMhr5YsAYmHAB+gRFZFMGX7aZ7UcgFyDEwo5fiNG9+dPTJVqmHnJp3PaZO1YBpcUV9UckTOnpf1d+oJ+88DFkhsv7HcfT6ZuVMbc70u0yWa6nZ9B482pyOazALeeT3AoN7n1teZ7giCkVGe363L2x0wyEhOlGZE3La9hEDGmfYACiObdCwGkh+i+xnCZud7Y624GTGc3F34FDYS8MIuKrMfw21Kz1kRhVcpq+DqYqSn2i+gBQxc+Y6lcWyu67FmD6+8X8cnA2Z5IOL11x1lGaEtgyrHTWJK1lRHD5O5zyt8q6UmiEMbJ2mq2UCEn.En.En.En.En.En3BhUOqO0HHKKAjiae9EcE0mcwSGySQmSuYSd8sz+sLUjLq9a0mXGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbHGxgbH2uzb5KzgWbivN3pJ7ju.u73PAJPAJPAJPAJPAJPw2wkG2I2n2826182i2+Nub2cz4W8J71a7U3Mic0KNc8E2sPkv2qujtuLm9x1F5n7DQ91awkACTqDQFOWeQceyqNbyAWc8Vr00Od86H8HJwzlDRVcZcyjI7aM1FfWvSgb2Nb8tBxM772s4gzQWs49dN25pMeQ3hYVASr+fUDwdh0rkKlYG3N2YpevO5UadLDkTLzW2TvvLSexXeg7K73lTYAkiz9S+SV5GsN9GchwGD76u.7fmpsRZG+va9P3iXhwn.En.En.En.En.En3slXbWNniSybbtfmOcuymu4fzf6S4lN+t+B5u5jHubR29iS5VjuuRY0jGT+uxP8acYCYn3OnpJ3PFRPazmv+URf09UmJZTPzsREc1zPeK2I9KslLY5DKBIZl6rvoS8lYOLUT5aHUz0OtusKa0j0RYZuZrgkVpsaw6X447zakxdssbnYryt0goCTpIggs5l8aFq7quh16EGHSmCcnypWILOp0CNvFc+bs.mfwANu1yh4UFu7q4YqPo9m4vUn0Qzgzqb5JtDWKWeWHjFBksVtj5SmL01yKLbXHs8aHjlktUVHT6xtkQfksOUnpRFo5CvdWTDo9Ujmiefqis+ylemSZtoeGLQY6uXq0F.lnW6T83kGp1Zq8lB92p34wWgSiskIxuNADDI1HfQ5MrgxXE6vsCska1TxUurKcFDhUe3TubGjF6r4.W5Qq0OscPLO6A3trfAJV5ceTJJ4WcggvQKLb14I1jwySH0yRr8cu7zjvHXQe2Y9yslrzy0xwym5tLbA0Yd3O3gPNzP2q2eR+eUl8xB0ceB1s9pJdz3UDAm58m5iuevlnkhs4rTiiaSPtwdtMAkGos+tnoud529d4myk5PCZbpD+qrc9bWhkqczBqINKbsBcmFLa5jnEQ91+nq80XYux5Yc1yWAC8ZLi2xkzumauC6TGh4wXhyNm63RBWJlqceqph3iyypDmdb5cSp.4+IkYMFwRdZ2AoanO79H3u5NxyP+uHTOG1zPaJsMfEf9e.bmeVEC
--end-wire-patch--
tijnisfijn
I will draw lines and just mask out the brightest part of the texture and fill those with the lines.
like this
If I read the original question, I think that's what he's after.
For anybody who likes I compiled it into a effect. Usable in avenue and arena and editable in wire.... Have fun with it.....
Lines 2 Brightness by Tijn.wired
(36.44 KiB) Downloaded 448 times
col-neck
Post by col-neck »
Thanks for your replies. It's a nice effect, that you created tijnisfijn but I thought of something different: I'd like to draw lines b e t w e e n the bright parts, e.g. to connect the lights in your example.. It seems that it's indeed impossible in the actual Wire version.
I couldn't copy and paste your patch, Arvol: it seems like it is made with a beta(?) version of Wire 7.20
tijnisfijn
OK then I misunderstood, that unfortunately is not possible at the moment, but hopefully will be in a update.
This was the patch
Then I was just trying to figure out how drawing lines between points was currently happening? lol
Assumed it was an ISF patch?
But yeah, natively in Wire there isn't a way currently.
