Bug ? Copy paste effects
Grimm90
Post by Grimm90 »
So might have found a small bug , not sure...
ok full story :
I got single frame DXV's , mostly DJ logos png's which i converted with alley to dxv with alpha.
Got them in resolume , made a nice effect stack on the image to make it juicy.
In this case i got :
Shift glitch
Goo
Ripple
Shift RGB
Shift RGB
Trails
Hue Rotate
Edge Detection
Vignette
Ok , now in Shift RGB , the "R'' parameter is animated to BPM Sync / Random mode (speed 8 - Interval 1/8 - Distance 10 )
If i copy effects of this now juicy ready image clip , and i paste it to a similar other DJ name single frame DXV , the R parameter in Shift RGB is still there and set to BPM sync , but its frozen. I got to put it to basic or timeline and back to bpm sync to work.
tijnisfijn
Re: Bug ? Copy paste effects
Post by tijnisfijn »
Seems like a bug... I could reproduce it and I will make a ticket, but can you tell me does it also work again if you change the BPM sync play direction from forward to backwards and back to forward?
Grimm90
Post by Grimm90 »
just tried it and yep that fixes it too
