Text block to display a $variable?
Hakol.Sound
Post by Hakol.Sound »
I'd like to figure out a way for Text Block to display current Column# and maybe The one next to it.
Is it possible from within the app? Should I try my luck with the webserver?
What is the way to go?
Re: Text block to display a $variable?
Text fields don't support getting variable values, but you can send these to the fields via OSC or the API.
