Slice Animator
Sjan Top
Slice Animator
Post by Sjan Top »
For all the Slice addicts, a little wire patch to control your slices in a new way.
The patch is ready to use, but it is made to inspire you to add on you own logic and needs.
Add delay or smoothness to the inputs, Linear or Random ...?
You want to animate Slice in groups? Just copy all the nodes in the patch, and there you go, you have groups.
I did not do all that because there are so many ideas that the interface in Resolume would be a nightmare. So have fun with building your own :)
I have a mask heavy workflow, so this one is mask galore. And i'm running a 7 group version myself, i use masks to create animated assets. https://www.instagram.com/p/C71kLHjqhL-/
*updated the patch so you can scale the slices now, and used the linear node now on a more logical spot.
Animated Slice Updated.wire
(233.69 KiB) Downloaded 1505 times
Fxcu CRX
Re: Slice Animator
Post by Fxcu CRX »
is there a way to have this plugin in .cwired so i can open on resolume?
Thank you
Sjan Top
Re: Slice Animator
Post by Sjan Top »
Hi Fxcu CRX
this patch uses mask inside the patch, and there is no interface in resolume to change them.
So that is why its a .wire so if you have wire, you can use it.
If you don't have wire, you can check my Animated Slice Transform plugin on Juicebar. That plugin has all the same functions except the masks and works stand-alone in Resolume
Re: Slice Animator
7.22 has an image and video input parameter, you can use for custom masks and videos:
Képernyőfotó 2025-04-07 - 19.50.48.png (17.83 KiB) Viewed 26989 times
Sjan Top
Re: Slice Animator
Post by Sjan Top »
hey Zoltán,
i know i talk about that with Thijn before it was a thing.
But the latest version of Resolume are not compatible with win8.1 so i'm not in a hurry to update my license.
I have a list of plugin i'm building for Juicebar, it will take some time before i need 7.22 and update all the plugin to 7.22 Now they are compatible with 7.20.1and up
Fxcu CRX
Re: Slice Animator
Post by Fxcu CRX »
i have a missing file:
I dont know, but it is on the "ONE Masker Pre" and goes to Resize in the first Step.
is really necessary this file?
Thank You
Sjan Top
Re: Slice Animator
Post by Sjan Top »
Hi Fxcu CRK
No i think its the mask i used in the preview, you can change it with your own or unmount them in the mask nodes.
Fxcu CRX
Re: Slice Animator
Post by Fxcu CRX »
Thanks!!! :D 8-)
Re: Slice Animator
What's keeping you on windows 8?
Sjan Top
Re: Slice Animator
Post by Sjan Top »
Hi Zoltán, we talked about this before via mail (Sjan Top)
There are a few reasons.
i don't like the road windows is on
The laptop daily use is from 2018, and i don't want to clog op its gears with a heavy operating system.
And its been stable for years now, so why mess that up.
I have a new laptop (2024) with windows 11, but there is no personal stuff on it.
And every time i disable the windows update its gets activated again, and then i have to trust that windows does not bork a update. Its not something i like to worry about in busy times and with my personal system.
Now both system run the same version of Resoluem/wire, so i have a backup for shows.
If i start working in newer version of Resolume/win11, i loos my backup.
There are feature that would be nice to play around with in the newer versions (Resolume/Wire). But its not enough to compensate my other consideration.
Probably in time the Juicebar plugin's will pay them self’s and then i will extend my license to create more/new plugin's. But for now i have backlog of patch i can work on and publish that work fine in 7.20.1. So for now there is no need on that front.
So thoughts... :P
