Macbook Pro aspect ratio problem
ManDerLa
Post by ManDerLa »
Hi. I have some problem with aspect ratio when using Resolume on Macbook Pro M1. When external monitor is connected, MBP display proper aspect ratio, but when I use Resolume, aspect ratio is different (for example circle is more oval). This issue sometimes happen, sometimes not. I can fix it by changing scale W to 110%, however could be nice to know why is happening. I've tried several monitors and projectors with the same result.
Re: Macbook Pro aspect ratio problem
Different on the output or the Resolume monitors?
Do you conenct the external display after starting Resolume or before?
ManDerLa
Post by ManDerLa »
On external monitor/projector. Mostly projectors. I connect projector before launch Resolume.
MacBook Pro M1 2020, OS 14.2.1, Resolume Avenue 7.13.2.
