automation
stefanocps
automation
Post by stefanocps »
hello just downloaded the demo of arena and trying to understand if it is for me
At glance i like it,but there is something i need to knowbefore all
Is it possible to create a sort of automation,where i can tell to a certain fx to change a certain parameter from x at time 0 to y at time 1?
this is fundamental for my need, need to know before i dive in the sw
thanks a lot
Re: automation
Yes, in Resolume Arena, you can create automations by using envelopes to adjust parameters over time. Although there is no traditional timeline, you can set envelopes for specific parameters to change from value X at time 0 to value Y at time 1.
best wishes
tijnisfijn
Re: automation
Post by tijnisfijn »
If you were really looking for more of a sequencer where you can record controllers, parameters and notes, like you would control a synthesizer, then you could use arena in conjunction with for instants Ableton live. Then you could do the sequencing in Ableton live and that would control Arena like a very extensive video synthesizer....
stefanocps
Re: automation
tijnisfijn wrote: Fri Jun 14, 2024 10:26 If you were really looking for more of a sequencer where you can record controllers, parameters and notes, like you would control a synthesizer, then you could use arena in conjunction with for instants Ableton live. Then you could do the sequencing in Ableton live and that would control Arena like a very extensive video synthesizer....
great!
this is exactly what i want to do!!I use ableton live for music and i want to "sync" to videoing!
I see the "link" function, but i don't think this is enough, right?how do i do that?
tijnisfijn
Re: automation
The link function is only to sync the tempos together, so your movies will play in the same speed as you're Ableton composition. By the way there's only works if your clips are set to bpm instead of timeline. To control different parameters in arena from within Ableton you need to use OSC or Midi.
Check out this page about OSC https://resolume.com/support/en/osc
There are also quite a few max4live plug-ins that have to do with Resolume so you can definitely have a look there as well.
I found these tutorials, when searching for Resolume and Ableton on YouTube, but there are more
Hope this helps you on your way...
stefanocps
Re: automation
ok one more thing, perhaps more difficult
Is there a way to connect arena to premiere?the simpliest thinh, to rout the utput of one to the input of the other?
stefanocps
Re: automation
tijnisfijn wrote: Fri Jun 14, 2024 15:07 The link function is only to sync the tempos together, so your movies will play in the same speed as you're Ableton composition. By the way there's only works if your clips are set to bpm instead of timeline. To control different parameters in arena from within Ableton you need to use OSC or Midi.
unfortunately this project is abandoned, so those plugins are not available anymore
I have found his https://support.showsync.com/sync-tools ... troduction
but i see little info about, and don't know how to make it work
tijnisfijn
Re: automation
this should still be available.... https://www.showsync.com/tools#resolume I hope that helps you out.
stefanocps
Re: automation
yes it is what i am tryng to use, but i haven't sort it out yet!can't find proper tuorial at the moment
tijnisfijn
Re: automation
I know this is not a video tutorial, but here is the manual
and together with this, link how to use OSC in Resolume
i think you should be able to figure it out with that...
And I also found this other one https://www.pixelclone.com/software/blo ... cmpte.html
That you could check out.
